3rd_gear_Ted's Avatar
Lightbulb Heat exchanger shell deletion
Knowing that 911 heat exchangers need airflow through them during track conditions or overheating occurs due to thermal heat build up. Would a possible solution be to remove the heat exchanger shell from around the exhaust pipes? Would the thermal conditions underneath the motor during track conditions be effectively the same as having a header? Its amazing how this condition only occurs @ the track (SOW) or the AX course. Please let me know if I'm nuts or am I forced to do a heater backdate.
Old 10-25-2008, 01:32 PM
Senior Advisor
James Brown's Avatar
Thumbs up
if you don't need the heat like l do, than it won't hurt anything to do that. you can fab some block off plates (saw a post on here two days ago) and rip that crap off!
08 Cayenne Turbo
Old 10-26-2008, 09:58 AM
it's kind of a bittch to remove. stainless is tough.
206 637 4071
Old 10-26-2008, 12:27 PM
