irl irl is online now
irl's Avatar
Send a message via AIM to irl
School me about a brake upgrade please
I have a 74 with stock everything brakes. If i upgrade to something better like S calipers, what upgrade do you recommend that wont be off the chart expensive and what else changes, rotors?,master cylinder?
Thanks,
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 09-17-2010, 03:06 PM
Bill Verburg's Avatar
Thanks,
if you change to S calipers form M you first need to change the struts.
S and almost all upgrades will use 3.5" caliper mounts, M uses 3". The only 3" upgrade is a BMW caliper.
never go to a larger m/c unless you have changed to calipers w/ much larger caliper swept volume. All M, S & A setups use the same 19mm mc for unboosted aps and 20.6mm for boosted apps. When you go to 930/0964/993 calipers then you need the 23.8 or 25.4 mm m/c's
Bill Verburg
Old 09-17-2010, 04:05 PM
Dr.Benzin's Avatar
Witch BMW has 3" caliper mounts who would be an upgrade on a old 911 with M calipers ?
Old 09-18-2010, 12:16 PM
AutoBahned
RWebb's Avatar
many "upgrades" are really downgrades
big brakes (unless you use ceramic rotors!) add wt. to your suspension - larger, heavier brakes are the last thing to do even if you change your system
are your brakes overheating?
- change your corner entry style
- duct air to the brakes
- lighten the car
- find a new track
- last, put heavier brakes on
Old 09-18-2010, 12:21 PM
cfries's Avatar
I have the BMW upgrade. The mechanic in south Florida who put them on stated they were from a 7 series BMW, but couldnt remember what year. They work great on my '75 and were a direct bolt on. I havent replaced the pads yet, but when I do, I'll find out.
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 09-18-2010, 12:28 PM
Max Sluiter
Flieger's Avatar
Contact Eric Shea at PMB Performance. He restores and sells the 3" spacing Brembos. (the BMW caliper) They are a little lighter than the S caliper.
Brembo AM-Caliper: The "ULTIMATE" M-Caliper Up-Grade!!
Old 09-18-2010, 04:35 PM
H-viken's Avatar
Is there a site with weight comparisons between the different calipers and rotors?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 09-19-2010, 06:22 AM
Brakes
David G PCA
'72 S/T
'74 Euro Carrera
'95 RS --SOLD
'77 930 Steel Slantnose "Wedgie"
'57 Speedster planter
Breeding family of Volvo/ BMW Wife + kid mobiles
'Rib-Breaker' '01 CRG 125 shifter kart
Aprilia RS50-weedeater with fairing
Old 09-19-2010, 06:57 AM
Does anyone know what year / model BMW had these calipers? TIA. -John
'73 RS Clone (flared, lowered, backdated, swapped)
'72 124 Spider (newest project; shaved & lowered cruiser)
'97 328ic (wife's toy)
'05 3500HD D/A (tow vehicle)
Old 10-24-2010, 04:47 PM
PMB Performance
Eric_Shea's Avatar
Ya gotta stop saying that...
These are the best I've found.
Here's the low-down: These Brembos have a 3" bolt spacing and the exact same offset as the M-Caliper. This means they'll simply bolt right on. When I say bolt on I mean... all the way. They even fit with the standard dust shields. The fluid inlet is aimed right up at the tab on the strut for a direct in.
They have the same 48mm piston as the M-Caliper, S-Caliper and the later A-Caliper. What's cool about this is, they are the later "cup" type piston with no knock-back mechanism to deal with. The cup design offers better cooling with much more surface area than the standard M and S-Caliper pistons. Also nice is the fact that this won't throw off your fluid dynamics with your current Master Cylinder. Again, Bolt on!
The pad size is much larger than the M-Caliper pad. They are the same width as the A and S-Caliper pads but not as tall... (only slightly, like 2mm or so). If anyone is familiar with the BMW 320i pad size, these are the same. Another nicety, as I mentioned that these add up in all areas as a true bolt-on upgrade is; with this basic pad size (which has been proven with the S-Caliper and A-Caliper) there is no over stress of the standard 20mm rotor which obviously lived on all 911's through 1983.
They weigh in a full 4lbs lighter than the M-Caliper so there goes a good chunk of un-sprung weight (yes, they're aluminum!). Did I say "Bolt on upgrade!"?
You simply take your M-Calipers off and stick them on the shelf (in a plastic bag of course) for posterity sake, bolt these on, bleed the system (you know you should do that this year anyway) and you'd be good to go!
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 11-09-2010, 04:30 PM
Racer
winders's Avatar
Isn't the real test for the master cylinder change the area change in pistons? You could go to a caliper with much larger pads ("larger caliper swept volume") yet have the same piston area.
Eric_Shea's post is a perfect example of what I am talking about.
Scott
Old 11-09-2010, 04:38 PM
Scott
that is what I said you are misreading and confusing volume w/ area.
caliper swept volume is the piston area x piston excursion which is the volume of fluid the m/c needs to provide, a bigger m/c pushes more fluid,
caliper swept area is the the annular area swept by the pad, this has nothing to do w/ the m/c
Bill Verburg
Old 11-10-2010, 08:57 AM
Racer
winders's Avatar
I am not confusing the two. I just misread what you wrote. For some reason I read "area" instead of "volume". My mistake.....
Scott
Old 11-10-2010, 09:15 AM
MBruns for President
JeremyD's Avatar
Also depends on what you use the car for. Mine sees the track - and I am planning on a bigger motor in the future... So - and yes even with 3" caliper spacing - also a 74 - I switched to 993 front calipers - the machined down caliper and hat from Steve Weiner - rennsport systems (the wilwood rotors work too) - 965 rear calipers over a 930 rear rotor. I also installed a 23.3 Mercedes Benz non boosted truck MC (but be advised that you need a longer brake plunger pin)
Listen to Bill Verburg - he can definitely steer you in the right direction.
Old 11-10-2010, 09:24 AM
T77911S's Avatar
if your brakes can lock up the wheels, and they dont fade out due to heat, (vented rotors with plenty of air), is there really any brake improvements that will shorten your stopping distance until you put on a tire that has more grip?
when i was looking at brakes for the BWM, which dont even come close the 911, someone said if the brakes can lock up, i am wasting money with bigger calipers/pads.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-10-2010, 10:59 AM
AutoBahned
RWebb's Avatar
that person gave you xlnt. info - big bad boy bling brakes are heavy and inhibit suspension action
you DO want to ensure that they will not fade under all conditions you will encounter in the future, given new fluid and any air ducting, yada yada...
Old 11-10-2010, 11:14 AM
PMB Performance
Eric_Shea's Avatar
Spot On...
What Randy said...
I restore a lot of brakes and the word "upgrade" is visiously tossed around by the online "Bigger is Better" crowd. A full 95% of the people who "have to have" an "upgrade" do not need it. When pressed they "might do an occasional auto-x now and again".
BMW calipers? Most are basically the ATE A-Caliper casting with a 3" spacing. Those are the absolute heaviest caliper Porsche ever put on a 911 at 9lbs 4oz each! Go with the Carrera version... add a 24mm (not needed) rotor to your early 911... say hello to nearly 20lbs of unsprung weight on a car that would be damn near impossible to get "fade" out of in stock trim.
Those Brembo's come in at 4lbs 8oz.
Want a break on brakes? Get yourself a full set of Porterfield R4S pads... bed them in properly and enjoy your new found stopping power. There's your upgrade.
855-STOP-101
Old 11-10-2010, 12:59 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
ok, I am interested in trying these porterfield pads. any recommendations for where to get them?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 11-10-2010, 05:21 PM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
This might be a stupid question, but how are the porterfields when it comes to dust.
My wheels are the bbs basket weave style, and I can't take it anymore with the stock compound.
What would be a great pad that has minimal dust? Primarily street, occasional track.
Thanks. Hope this doesn't count as a hijack.
Micjael
Old 11-10-2010, 05:55 PM
Max Sluiter
Flieger's Avatar
I got mine from Eric. They do not seem to make any more dust than the normal Textars/ATE combo I had.
I think it is silly to ask brake pads to stop and not make any dust. It is like running while holding your breath.
Old 11-10-2010, 07:59 PM
