irl irl is offline
irl's Avatar
Send a message via AIM to irl
What is a carb float check tool and how does it work
What is a carb float check tool and how does it work, or how do i use it.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-04-2008, 11:04 PM
3.2 CAB's Avatar
If it is what I am thinking about, it is usually included in most carb rebuild kits. It is a measuring device, to check that you have the float at the proper level, if not you have to adjust(bend) the float arm so it is in the correct position, to actuate the needle valve that lets fuel enter the fuel bowl on the carb. Float too high, results in flooding because the float is not able to shut the needle valve, too low, it is not letting enough fuel in the fuel bowl to run engine properly. Hope this is making some sense. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-04-2008, 11:57 PM
The one I am familiar with is sold by youroil.net.weber-carbs. It is a vial shaped clear plastic unit with graduation and a screw which mounts into the drain hole of the float bowl. It shows the level of fuel in the bowl while the engine is running.
It's a nuisance though as you have to keep mounting and dismounting it and spilling fuel in the process. I finally started using it on one float bowl only and the measuring the height of the float by dropping a plastic straw from a spray lubricant can down the vent pipe and marking it when the float level was where I wanted. Crude perhaps, but it sure saves a lot of time and spilled fuel. At least I am able to "ball park" doing it that way.
The floats are adjusted by raising or lowering the needle valves through shim washers.
Good luck.
'65 911 Coupe (301278)
Old 11-05-2008, 07:20 AM
