irl irl is offline
irl's Avatar
Send a message via AIM to irl
Please point to the float bowl plug
Can someone upload me a pic and point to the outside float bowl plug on 71T weber carbs. Ill upload a photo if necessary
Thanks.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 11-05-2008, 02:58 PM
jwetering's Avatar
Here's a good photo, but I don't have any photo editing software so I've cropped the picture to show the float bowl plug. Hope it makes sense otherwise another pelican can maybe mark up my photo.
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 11-05-2008, 03:17 PM
What is injecting into the manifolds?
'80SC ROW
'76S Wide Body
'87 G50 Coupe
'69T Bahama Yellow
Old 11-05-2008, 03:24 PM
1QuickS's Avatar
Float bowl plugs are the two 10mm hex head brass bolts. See item #64 on the attached link to an exploded drawing of the Weber. http://www.performanceoriented.com/Carb.htm
To check float levels you will need a gauge and screw it into the hole where the float bowl plug was. Mind the gas that runs out. I modified my float gauge (see picture) to collect fuel during adjustment of the float valves without continued fuel loss.
Set fuel level to have the meniscus between the two upper lines, fuel height between these two lines is equal to about 0.010" change in shim thickness. Engine should be very warm before final setting and you need to take readings while the engine is running. Fuel pressure should be in the 3.5 to 4.5 psi range. New floats are a good thing to have as well. Sometimes the floats wear little divots on the lever arms on the floats themselves which may cause sticking. With a little care you can polish these divots away.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-05-2008, 04:06 PM
irl irl is offline
irl's Avatar
Thanks, I bought a float guage from PMO and this is exactly what I needed. I will photograph the process and post if I dont catch on fire.
Thanks again, this place is awesome
79 SC unmolested
25 GTS
Old 11-05-2008, 06:59 PM
jwetering's Avatar
That's where I tapped the manifolds for vacuum so I could run my power brakes. This instalation was on a 1978 SC.
jasper
Old 11-05-2008, 10:59 PM
"I modified my float gauge (see picture) to collect fuel during adjustment of the float valves without continued fuel loss."
Interesting setup. Can you explain how you would lose fuel while the PMO gauge is attached? Do you mean if the float level is too high and overflows from the top of the gauge?
Thanks,
Sherwood
Old 11-06-2008, 01:38 AM
1QuickS's Avatar
If the fuel level is above the top line I unscrew the valve (brake bleed screw) and lower the fuel level so I can reset the shim stack under the float valve.
Paul Abbott
Old 11-06-2008, 07:26 AM
jwetering's Avatar
nice mod - wish I would have seen this a few years ago.
jasper
Old 11-06-2008, 10:20 AM
