Post Chain Rails
Pelican have two parts listed....one is black needs one...other is brown,.,..needs 5???
Help
Old 05-30-2001, 06:10 AM
rstoll's Avatar
Post
I think it is one brown and the rest black.
Robert Stoll
83 SC
83 944
Old 05-30-2001, 06:32 AM
Recreational Mechanic
Nickshu's Avatar
Post
You need 5 black and 1 brown.
Below is a diagram of how they go in. Once you have the cam covers off, you'll need to remove the engine mount yolk that bolts to the back of the engine, after placing a jack beneath the case to support the engine. You can then access the bolts that go thru the rear plate of the cam housings and remove them while holding the end of the inboard rails with needle-nose vice grips (Don't drop them!) The 2 outboard rails just pull off their small studs.
[img]http://www.***************/am/assets/images/rampdiag.gif[/img]
Good Luck.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 05-30-2001, 07:13 AM
