Greasy Member
Need offset/spacing help.
Hey all, I usually hang out in the water-cooled section, but need to know what the normal offset spacing is for a set of cookie cutters from a '75 911?
Thanks, Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
'75 911 would have had 6x15 ET36
Non Compos Mentis
Porsche used only two sizes of Cookie Cutters: 15 x 6, and 15 x 7. All are early offset.
The 911 used 6 in front, and 7 in the rear, the 944 used 7s all the way around. All the 7s have the same part number. No distinction between 911 and 944 wheels. |
from '78 US SCs were available w/ 7x15 ET23.3 in back and the 6s in front the '74 thru '77 Carrera 3.0 & 2.7 also were available w/ the 6 & 7 x15 cookiecutters
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Non Compos Mentis
Interesting. My '73 came with 6 & 7's, so I thought that was standard fitment for 911s. I bought it from an auction, so I have no history for the car.
I don't use the Cookies any more. 7 & 9 x 16 Fuchs for street tires, 17" Fikses for the Hoosiers. |
It's hard to believe that you use 9's w/o also having SC/Carrera flares
Non Compos Mentis
I bought my car at an insurance auction, after it suffered a minor engine fire. Perfect candidate to drop the whimpy 2.4, and stuff a 3.2 in its place.
The donor car was a pristine 1987 Targa that was hit hard in the nose. It donated its engine, wiring harness, aluminum banana arms and brakes, and lots of little bits and pieces, along with its rear flares: ![]() So what wheels would have been stock on a 1973.5 911T ? |
