abit off center
cgarr's Avatar
Snap-on Stud puller collet
Well, when they are out of stock you need to do what you need to do, nothing with being cheap, but these collets are not that hard to make, just need to cut the reliefs. This is a homemade 6x1.00
______________________
Craig
G2Performance
Old 02-27-2009, 07:53 AM
Friend of Warren
Nice work!
Kurt V
Old 02-27-2009, 07:56 AM
you need a band-aid.
206 637 4071
Old 02-27-2009, 08:34 AM
Some homes are better equipped than other homes. My home has nothing that will turn out a piece of work like that. I do have lots of band aids.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-27-2009, 09:57 AM
pwd72s's Avatar
Evren has the whole set of metric ones...but considering their cost, I've often wondered why somebody hasn't set up a rental on them...I mean, other than a full time pro, how often do you need them?
Great Job of making one!
Old 02-27-2009, 10:04 AM
EMT/TechRescue Instructor
86911cab's Avatar
I didn't even know band-aids came in metric! I gotta get me some, cause rentin 'em is outa tha question!
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 02-27-2009, 10:25 AM
abit off center
cgarr's Avatar
Well its done and works great, now to make an 8mm smooth bore for pulling the dowels on the heads.
Craig
G2Performance
Old 02-28-2009, 09:00 AM
Elombard's Avatar
I am not 100% how it works can you show a picture of it on the stud?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-28-2009, 11:08 AM
abit off center
cgarr's Avatar
As you tighten up the collet it clamps down on the threads without damage then you just spin it out.
Craig
G2Performance
Old 02-28-2009, 03:12 PM
Elombard's Avatar
OK I just needed to see the other end. Looks like a very handy item when working on old stuff.
Old 02-28-2009, 03:51 PM
Hey Craig, wish I had that tool yesterday. Figured that all my extraction tools would do the trick, but as you know those two gave me a hard time. I drilled out one (took me about 3 hours) and it doesnt look pretty, but should still be ok. I think i will install case saver with jb weld just to strengthen it. All others look great though. Luckily the two iffy broken studs are on different cylinders so we shall see. Any thoughts on jb welding a case saver in a not so perfect hole?
Old 02-28-2009, 07:16 PM
abit off center
cgarr's Avatar
Just made the smooth bore 8mm for pulling the dowels. A twist and a pull and they come right out, no damage to the dowel either.
Craig
G2Performance
Old 03-01-2009, 10:58 AM
Thats really cool, nice work.
Makes me wonder if a good quality 1/2" drill chuck could twist and pull out solid locating dowels like that. Especially if you heat the head then hold an ice cube on the dowel for a few seconds or more first.
Old 03-01-2009, 11:32 AM
Nine9six's Avatar
A 1/2" drill chuck would not distribute the holding/clamping power over the same surface area as Craig's collet setup does. Perhaps the use of some shim stock around the dowel would prevent any marking/marring. However. if I had a choice, the collet would get the nod every time.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-01-2009, 03:20 PM
Elombard's Avatar
Why do you even have to remove the dowels? So you can machine the surface?
Old 03-01-2009, 03:44 PM
abit off center
cgarr's Avatar
If the sealing surface is bad (head to cam tower) sometimes they have to be surfaced, if you have leaking in this area I bet your surface is out, and once you start to surface them you can really see why, but that does not happen often.
Craig
G2Performance
Old 03-01-2009, 05:10 PM
