Will I Be Able To Replace The Rear Shocks With The Engine & Trans Removed?
I believe my 23+ year old 911 has the original shocks and struts and hope to replace them over the winter.
Having never done this before I'm wondering whether I'll be able to replace the rear shocks with the engine and transmission out since the rear of the car is about 5" higher with the weight removed? It obviously looks like it will be simple to get to but I'm concerned that the shocks will not extend enough to connect both ends.
Does anyone know for sure that the rears can or cannot be replaced with the engine and trans removed?
Thanks.
Dom
1985 Black 911 Targa (Sold)
2007 Chev Malibu SS (wifey's car)
Old 11-23-2008, 03:05 PM
the the is offline
yes you can replace them with the engine and trans out, no problem.
Old 11-23-2008, 03:14 PM
Oh Haha's Avatar
No problem at all. You may need to jack the control arms up to meet the shock to put the bolt in but that's it.
Pacific Blue
Wayne
Old 11-23-2008, 03:16 PM
Mitch Leland's Avatar
Replacing shocks...
No problem... I just did last year... In fact it makes it a lot easier to get at the back mounting nuts.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 11-23-2008, 03:26 PM
By the way, my car, without the engine or transmission, is on a drive on lift so jacking the control arms will not change the distance between the upper and lower mounts. This is the primary reason I am asking the question.
Dom
Old 11-23-2008, 03:45 PM
mca mca is offline
mca's Avatar
I think I tried this when my engine was out. I had already installed the rear shocks prior to the engine drop - while it was out I wanted to make sure the shocks were torqued properly.
When I put a jack on the control arms the entire rear lifted up due to absence of the engine.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 11-23-2008, 04:09 PM
