Moke81's Avatar
Wipers go on randomly
Yesterday my wife and I went for a ride along the coast. A couple of hours went by thats when it started. The wipers would go on at random times.
I checked the intermittent wiper switch on the dash and it was turned off.
Anyone know whats going on?
Barclay
________________
1981SC Coupe
Old 11-24-2008, 06:24 AM
wiper switch is the usual culprit.
206 637 4071
Old 11-24-2008, 06:44 AM
Friend of Warren
It is a pretty easy DIY to pull the switch and clean the contacts. I did it a few weeks ago.
Kurt V
Old 11-24-2008, 07:07 AM
Designer King
Paulporsche's Avatar
Cleaning may do it, or you may need to bend some contacts to their original configs. I think there are some threads showing pics of opened up switches.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-24-2008, 07:31 AM
abit off center
cgarr's Avatar
Mine always goes on at autox's for some reason!
______________________
Craig
G2Performance
Old 11-24-2008, 07:50 AM
You might want to check the flailing hands of the driver, that's the usual culprit!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 11-24-2008, 09:58 AM
Happiest when Tinkering
gsmith660's Avatar
I have the same problem sometimes when I adjust the mirrors and once in a rare time when I open or close the windows. Any ideas?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-24-2008, 10:07 AM
Moke81's Avatar
I have bumped it several times before but thats not the case this time.
Also when the headlights are on it seems to be the time it does it, when the headlights are off the wipers don't come on........weird
I already replaced the turn signal switch can't be much harder than that.
Thanks for all the input.
Barclay
______________
1981SC Coupe
Old 11-24-2008, 10:52 AM
Moke81's Avatar
Replaced wiper switch but problem still there. Also this problem happens with the headlights on.
Barclay
_______________
1981SC Coupe
Old 11-30-2008, 09:45 AM
crustychief's Avatar
check your grounds. It sounds like the lights are feeding through the wiper motor. same with the power mirrors and or windows.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-30-2008, 11:24 AM
i had one last week that cycled the wipers once each time you revved the engine from idle. light switch on only. wiper switch didn't fix it on that one either. shut off the lights, turned engine off, then started again and turned on the lights and then it wouldn't do it. i'm thinking the intermittent relay is getting a power surge, but i'll find out later this week.
206 637 4071
Old 11-30-2008, 11:38 AM
