Zeke's Avatar
I made this and now can't seem to figure out how to get it apart (C2 lid question)
I guess I jumped the gun because I have no idea how this section of the lid, the movable part, separates from the integrated grille and underside. I see seams, but nothing is moving and no screws or detectable fasteners are to be found. I can get the movable unit off as a whole, but that's useless to me at this point.
Help from the C2, 993 guys! thanks.
Old 12-01-2008, 12:43 PM
Zeke's Avatar
OK, according to the PET diagrams, the 993 grille does come out separately. I don't have one to look at. Looks to me like the 964 unit (which is what I have) is bonded together.
No wonder no one has done this before.
Old 12-01-2008, 01:10 PM
e p slick's Avatar
Sawz-All
Sawz-All will do the job.
EP Slick
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 12-01-2008, 02:59 PM
Zeke's Avatar
no soup for you.
Old 12-01-2008, 03:05 PM
3.2 CAB's Avatar
Milt, I believe that I also read that the piece is bonded and not really meant to be taken apart. I can't remember for sure, but I think Ronnie(RoninLB) had a write-up about this. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
blk911's Avatar
Milt,
I'm sorry I can't help, but I'm subscribing. Can't wait to see what you create next! Please keep us posted on your progress. Something between a ducktail and a Carrera tail would be really cool at least IMHO.
I feel the need, the need for speed.
Old 12-01-2008, 03:36 PM
Zeke's Avatar
Originally Posted by blk911 View Post
Milt,
You're saying I should build a cantilevered tail off the movable portion? You know, the possibilities are endless.
Maybe I should start my own version of the "special wishes" program. You want a duck tail grafted on a fish's head, we do that. Then we call that a "dufsh." Or we could call it a, er... I guess I can't print that.
Old 12-01-2008, 05:47 PM
hi Milt & Tony
the rubber is glued to the grille.
I have the C2 Workshop Manual pages if you want me to fax them to you. It's mostly 3 pages on where to place the bonding agent, the actual agent's name, etc. It also has a good 6 page guide on replacing the parts together after you forget how to reassemble. I did even with pics predisassembly.
I taped off the grille and painted the rubber. The grille needs a little work but not much either with a spray or a small brush to get to the hard to reach places where the grille tucks under the rubber.
I'm using carbs and a couple of parts had to be removed to prevent hitting the right carb air cleaner case in the down position. No big deal leaving them off.
I also used a Cole-Hersee DPDT #58027-11-BP $13 momentary 3 position switch like what's used to adjust small boat trim tabs. Hold 5 seconds to raise it and 4 seconds to lower. West Marine uses # 147913.
I'll post pics if you want.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-01-2008, 06:45 PM
Zeke's Avatar
I don't have any rubber. Are we talking about the same C2 lid?
Old 12-02-2008, 07:04 AM
sorry
flexible urethane
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-02-2008, 07:33 AM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-02-2008, 07:37 AM
