G50 Shift Fork Bushing help
Just ordered the last of the parts for the rebuild (hopefully) from our host and was told the hard plastic bushing that goes inside the upgraded G50 shift fork is n/a separately. I have the factory upgraded G50 clutch release in my '88 and I managed to bugger these up a bit when I was taking it all apart for inspection. I ordered new bearings/bushing but these plastic inserts are apparently now bonded to the shift fork and n/a separately. Has anyone got any suggestions or possibly dealt with this problem. I don't want to have to buy a whole new fork b/c of a couple of 50 cent pieces of plastic.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-03-2008, 09:44 AM
Bart_dood's Avatar
When you say shift fork are you talking about the actual end you use with your hand to change gear or the fork that presses on the clutch release bearing to disengage the clutch?
1997 Boxster SOLD
1999 R1100S SOLD
1988 Carrera 3.2
Old 12-03-2008, 09:57 AM
Nine9six's Avatar
Are the plastic bearings bonded to the internal thru hole in the shift fork? That's what it sounds like from your description. If thats the case, I cannot believe someone has not developed an oilite bronze bushing as a replacement.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-03-2008, 11:51 AM
Nine9six's Avatar
Shift Fork: The primary fork you shift to after finishing your salad. It's sitting just to the right of the salad fork
Baaah Haaaah Haaaaah!
All kidding aside, its the latter of the two.
96 993 C2 (Current)
Old 12-03-2008, 11:56 AM
911quest's Avatar
You will either have to replace the clutch relase or get the Weltmiester update with the metal bushings.
here is part number you can check it out thru Pelican
10-1518-090-M230
Tony Proasi
1969S
1957 VW Pickup
Old 12-03-2008, 12:09 PM
Can't seem to c/p pic over from the Pelican parts diagram. It's part # 950-116-086-06-M260. this is the roughly triangular shaped lever that the G50 hydraulic actuator pushes on to move the throwout bearing. I also would think the plastic bushings could be replaced and I guess I'll just have to see if I can find something that works in place of what was there.
Thanks for the replies,
Buck
'88 Coupe, '87 Cab,
Old 12-03-2008, 12:37 PM
Nine9six's Avatar
Here is the shift fork you were refering to...Pelican states this is NLA
No Longer Available
96 993 C2 (Current)
Old 12-03-2008, 06:26 PM
Nine9six's Avatar
I think this is what you need...
10-1518-086-M260
911 Factory G50 Update Kit (1987-89) - requires modification to fit $109.75
96 993 C2 (Current)
Old 12-03-2008, 06:35 PM
996 is right but the part has been updated, which is sort of the problem, there are now two versions of the part. I need the plastic bushings you can see in the pic above. The upgrade kit/parts in the immediate prior post is already installed in my car and does not include the two plastic bushings you can see in the post by 996. I have ordered, from Pelican, the two updated needle bearings and seals in the upgrade kit since they are available seprately. I'm back to looking for some sort of alternate solution.
Buck
'88 Coupe, '87 Cab,
Old 12-03-2008, 07:13 PM
911quest's Avatar
This is the part number I gave you in a previuos post it will work if you transmission has been drilled or not. You replace the plastic bushings with the bronze one's in the kit....
Sorry it's a Patrick picture.....
Tony Proasi
1969S
1957 VW Pickup
Old 12-03-2008, 07:22 PM
3.4 Bigger is better
88-diamondblue's Avatar
The one above is what i used when I updated the clutch fork kit. The bronze bushings replace the plastic ones in the shift fork. I got a used 993 fork on ebay since I needed the new design fork which were used up to the last model year 993 as well as using new bronze bushings in it.
If you can send the parts back and get the no drill kit. It fits both stock and the factory update holes. I do have the two pieces that were used for the trans that already had been drilled. It gets you the bushings and a better solution that will last much longer
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 12-03-2008, 10:57 PM
Tony/Michael,
Thanks for the education...I did not realize I had other options since mine has (I assume) been drilled out since the PO installed the early factory upgrade. Obviously I'd rather just replace the bushings for a couple of dollars but at least I know I have a solid option to buying a whole new release fork.
Starting to see the light at the end of the tunnel on this rebuild.
Thanks,
Buck
'88 Coupe, '87 Cab,
Old 12-04-2008, 06:41 AM
I have the plastic ones I removed when I did my clutch and shaft update. They are new as I just tapped them out and put in the bronze ones. PM me with an address and I can send them to you. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 12-04-2008, 09:05 AM
Nine9six's Avatar
Wow Ken, thats an awfully nice offer, but I think 88911 would be much better off if he follows your lead and uses the bronze replacements.
96 993 C2 (Current)
Old 12-05-2008, 02:10 PM
