Applying side script decals
I'm sure this topic has been covered before, but I can't seem to locate the thread. Any suggestions for the best method in applying the side script decals to the lower portion of a longhood's doors? Thanks.
- Mike
1973 911E
2005 997s
1964 R69s
1966 Stingray (sold)
Old 12-04-2008, 11:57 AM
Mike, I can give you generic instructions on putting film on a surface.
1). Clean area well with a grease wax remover
2). Lay the script where you want it and mark with pieces of tape, (outline the area).
3). Add a little, a few drops, of baby shampoo to luke warm water.
4). Remove the paper backing and wet with the lightly soaped water. Doesn't hurt to wet the substrate either.
5). Place the script in the area previously mark. Using a bondo squeegee push the air/water bubbles from under the film.
7). If you have any tiny air bubbles left you can use a pin to pop the bubble and press the air out. You'll never see them.
I'm sure others will chime in with other recommendations. Good luck and post pictures of your work!
O2 In Sully We Believe
Old 12-04-2008, 12:35 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
That sounds like the description of what I did to install my Carrera Stripe. I might add....let it sit for a day or so to completely allow the water to evaporate and the adhesive obtain its full bond.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 12-04-2008, 01:57 PM
KarlCarrera's Avatar
Don....very nice!
Thanks Mike and Mark, I have been looking for this info myself.
Karl
88 Targa
Old 12-04-2008, 02:17 PM
ruf-porsche's Avatar
Do people align the back of the script with the back bumper?
Old 12-04-2008, 02:57 PM
Thanks for the advice, and great pic. I plan to tackle the job this weekend and will share a shot of the finished product.
1973 911E
2005 997s
1964 R69s
Old 12-04-2008, 04:17 PM
Fritz Peyerl's Avatar
applying decals
I went and searched on u-tube and found a few short videos with some installation hints
Old 12-04-2008, 04:26 PM
Basically, according to the factory, the stripe was to be mounted to what amounts to be about 2'' above the rocker moulding. I forget the other measurements for where the letters are supposed to start on the left and right sides.
Don Booth
70 911 T Coupe
74 914
Old 12-04-2008, 04:34 PM
Side Carrera stripe install 2" up from bottom of door.
Driver side stripe, "C" starts 1/2" behind door forward edge.
Passenger side stripe, last "a" finishes just before forward door edge.
Porsche stripe on ducktail 1.4" above edge at the middle.
Carrera decal 6.25" down from top of ducktail decal starts 3.75" to the right of center.
Old 12-04-2008, 06:16 PM
Carrera 3.0 1975
André 3.0's Avatar
Carrera stickers DIY http://www.porscheforum.nl/viewtopic.php?t=9416&highlight=stickers scroll down
Old 12-05-2008, 05:29 AM
