-   -   R / Outlaw project... (http://forums.pelicanparts.com/porsche-911-technical-forum/445103-r-outlaw-project.html)
jsveb 07-26-2010 12:42 PM
I think you are doing a wonderful job - outstanding.
Jesper
jury 08-01-2010 11:51 AM
Fitted the 'parcel shelf', however its easily removeable using allen bolts. It makes up part of the removeable rear seat section.....should add abit of extra sound deadening.
http://i161.photobucket.com/albums/t...1/DSC01646.jpg
Will add another layer on the backside to clean it up abit...
http://i161.photobucket.com/albums/t...1/DSC01645.jpg
http://i161.photobucket.com/albums/t...1/DSC01647.jpg
http://i161.photobucket.com/albums/t...1/DSC01650.jpg
http://i161.photobucket.com/albums/t...1/DSC01651.jpg
jury 08-01-2010 11:54 AM
When I put my red car through its first UK MOT I needed to change the rear-light lenses. Whilst changing the lenses I tried to make the lights abit brighter by re-finishing the internal part of the unit. I thought about re-chroming, too expensive, spraying, too messy........baking foil and double side tape, perfect! I Updated these lights this afternoon. I would like to think it makes some difference...
Before...
http://i161.photobucket.com/albums/t...1/DSC01634.jpg
Foil on the flat and vertical surfaces...
http://i161.photobucket.com/albums/t...1/DSC01640.jpg
http://i161.photobucket.com/albums/t...1/DSC01641.jpg
http://i161.photobucket.com/albums/t...1/DSC01639.jpg
New lens in place, ready for final fitting...
http://i161.photobucket.com/albums/t...1/DSC01643.jpg
Chris
Joeaksa 08-01-2010 12:21 PM
Excellent idea on the foil and double sided tape! I have some fronts I need to work over and will try this on them!
dicklague 08-01-2010 01:38 PM
Are you going to put LEDS in there??
earlyaircooled 08-01-2010 08:15 PM
More nice work Chris, way to go
jury 08-01-2010 11:58 PM
The other option was to use mirror card...
http://i161.photobucket.com/albums/t...ver-mirror.jpg
...only problems being
A. did not have any to hand
B. maybe an issue if any water gets in?
jury 08-02-2010 12:06 AM
Thanks David:)
Any idea or leads on where I can get some 911 motor mounts? The actually metal brackets...
http://i161.photobucket.com/albums/t...1179114233.jpg
http://i161.photobucket.com/albums/t...1179114677.jpg
Cheers
Chris
Fishcop 08-02-2010 01:09 AM
Chris, great build - thoroughly enjoying it!
I thought I'd flag that the closed cell foam tape you're using for the bonnet doesn't have or create a channel to clear water... ask me how I know ;) The previous owner of my car did something similar, but only the factory seal has a lip that prevents water from slipping behind the main part of the seal and making its way underneath into the metal channel. As a result of this I'm dealing with some rust that developed under the channel of my car. I notice you've got another 911 to compare - you'll see what I mean.
Cheers
Northy 08-02-2010 01:33 AM
Hey Chris - a great build this. I've got it bookmarked!
You could try Douglas Valley Breakers in the UK for the engine mounts. You might need to persuade them to cut them from the car though.
Failing that, there is a guy on ebay breaking a 2.7 911 - he might do it, although some of his prices are a bit unrealistic IMO Ebay seller
squadra cavolo 08-02-2010 07:36 AM
Hi! What an awesome project! I like the seats as well, could you tell me where they're from? Bart
earlyaircooled 08-03-2010 02:59 PM
off and on Porsche has motor mounts in stock unless they have gone permanently NLA. Have you tried ordering new ones from Porsche?
Packy 08-03-2010 03:41 PM
make your own. I feel like the stock ones are flimsy anyways.
jury 08-03-2010 11:03 PM
Seats are Cobra RS classic, similar to the GTS Nurburgring. I got them from:
https://www.europaspares.com/SEATS/COBRA_SEATS/COBRA_SEAT___CLASSIC_RS___SIGNATURE_VINYL___CLASSR SIG01__5132.html
But they are also available through Demon Tweeks in the UK
jury 08-03-2010 11:05 PM
Sometimes it is that obvious:) I'll look through the PET catalogue and get in touch with Porsche
(May be over in Portland later in the year, will let you know)
Cheers
Chris
rw7810 08-06-2010 04:37 PM
chris - this is what I have;
http://forums.pelicanparts.com/uploa...1281141444.jpg
http://forums.pelicanparts.com/uploa...1281141458.jpg
squadra cavolo 08-21-2010 10:17 AM
Cheers, I had a look on their site:
https://www.europaspares.com/SEATS/COBRA_SEATS/COBRA_SEAT___CLASSIC_RS___STANDARD_VINYL___CORD_49 18.html
There seem to be two variants of the same seat... has anyone seen the two next to each other and is it worth forking out for the more expensive version?
jury 08-21-2010 02:14 PM
I think (but I may be wrong) the expensive option just allows you to choose different colours? But its the same seat either way.....
Chris
jury 08-21-2010 02:17 PM
No plans for LED's, but maybe at somepoint:)
Chris
jury 08-21-2010 02:21 PM
Cheers
Yep, realising this may be a problem.....I hope it doesn't come back to haunt me too much! Its an on going project, so hopefully it will get sorted;)
Chris
