LinkBack Thread Tools Rating: Thread Rating: 13 votes, 5.00 average.
jury's Avatar
Send a message via Skype™ to jury
Petrol tank cleaning...
This is how it looked earlier in the year, before welding the filler tube and neck in place. Cutting off the original filler neck gives a good view of what is going on inside, RUSTY...
Before the cleaning process starts, some prep work is required. Very important to seal off the tank, to stop nasty chemicals from spilling out...
Fuel sender...rubber and acrylic cap
Filler neck...rubber and formed (whacked with a hammer) metal
Breather pipe and outlet...PVC pipe melted to form a seal
Drainage outlet...PVC pipe and removable brake line clamp (to allow controlled drainage)
Plug...don't have a 22mm socket? M14 nut and bolt combo
Old 10-09-2012, 09:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #381 (permalink)
jury's Avatar
This is when it gets interesting. Taking advice from a Mechanical engineering student, its a long story
I decided to use some domestic drain cleaner first to clean out the tank (3 bottles used)...
Alot of shaking and tank spinning later the contents can be disposed of and then flushed out...
pretty clean...
Next step...5 litres of Phosphoric acid.....
More shaking and tank spinning
Flushed again...and repeat the shaking and spinning process with stronger 85% Phosphoric acid
Old 10-09-2012, 09:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #382 (permalink)
jury's Avatar
Though the results are great...
Flushed again and add 'Spiritus' alcohol cleaner to dry it out...
make sure its completely dry, then use POR 15 tank sealer.
Chris
Old 10-09-2012, 10:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #383 (permalink)
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Outstanding! I did something similar, but in a much smaller scale, with a motorcycle tank... I hope you had help shaking that tank!!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 10-09-2012, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #384 (permalink)
jury's Avatar
Fully dry, re-sealed and POR 15 Tank sealer added. I actually used 1 and half tins, and did the process in my previously mentioned engineering student friends garage. His (Stefan) engine lift/winch proved useful, as did his airline supply which was invaluable for making sure all the internal lines and tubes were clear during coating.
POR 15 added and rotated multiple times for 30 mins, then drained (through the breather as the original inlet is removed and blanked off), and I was amazed how much came out.....The engine lift/winch worked great to support the tank during draining, as did the crank from Stefan's 1938 Opel Olympia restoration
End results are great, it has been drying for a week now and the POR 15 is rock solid.
But some words of wisdom when using POR 15...
WEAR GLOVES AND LONG SLEEVES...DO NOT GET IN ON YOUR SKIN
Chris
Old 10-09-2012, 10:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #385 (permalink)
jury's Avatar
Still have the eye on the goal...
Chris
Old 10-09-2012, 10:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #386 (permalink)
brock911's Avatar
AMAZING, great on you and thanks for the updates.
Looking forward to your first drive.
Mike
Old 10-09-2012, 10:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #387 (permalink)
giovanni86's Avatar
my favourite project!
Old 10-09-2012, 11:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #388 (permalink)
jhlasserre's Avatar
What size tires on on the 944 spares?
Old 10-09-2012, 05:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #389 (permalink)
jury's Avatar
Tyre size is:
195/50 r 16 Continental Sport Contact 2
Chris
Old 10-10-2012, 04:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #390 (permalink)
jury's Avatar
Nope, still feeling the burn
Chris
Old 10-10-2012, 04:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #391 (permalink)
Wer bremst verliert
JohnJL's Avatar
Hi Chris,
You've done a fantastic job, full respect to your design and execution skills.
I also have a job that moves me around and am just starting another 'outlaw' project. Its possible I'll be posted in Germany next, within a year or two. I have heard nighmares about the TUV process, and this is in my mind now as I figure out how to end up with a car I can get registered. I had that problem in Australia.
Do you anticipate any problems getting it through TUV? How does that work?
John
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-14-2012, 09:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #392 (permalink)
twistoffat's Avatar
John I can tell you from experience that the German TÜV can be a royal pain in the A##.
With a car like an Outlaw thats based on an actual existing car model the problems are chiefly centered around mechanical additions are alterations carried out. You will often hear of the expression TÜV approved. This means that parts added which are TÜV approved will have accompanying documentation to certify the legality of their intended use. If for example you change the exhaust used from that on the standard model then the Sports exhaust will have to be TÜV approved and will have to be entered on the cars paperwork as a change. The rest is down to safety regulations such as brakes lighting etc. So long as the car fulfills the safety regulations you have to be more worried about additions to the project than what you have taken off. Once you have supporting docs for the additions thenn its all a question of being prepared before you go to the TUV
Old 10-15-2012, 12:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #393 (permalink)
Wer bremst verliert
JohnJL's Avatar
Does anyone have experience with TUV approval of body panels, gutting doors and changing engines, even if its the same model? The Candian authorities told me they only care its the same engine configuration and of at least a later year of motor. No backdating motors.
I'm thinking about what TUV considerations there are for changing body panels (76 to 73) gutting doors, replacing glass with Makrolan and installing a non-original motor (same displacement) but with EFI ITBs. And a rollcage. And GTS Seats.
Is there an "antique" exception?
John
Old 10-15-2012, 01:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #394 (permalink)
twistoffat's Avatar
John there is no antique exception. Glass is a safety product so if you change it and the manufacturer hasn´t submitted it in Germany for TUV approval then you may have problems getting the car registered. Also any car in Germany that is regarded as an Oldtimer and comes with advantages like cheaper Insurance and negligible car tax needs a so called "H" plate. To get a so called "H" oldtimer plate the car will have to be virtually original with some minor exceptions allowed. Changing Body Panels to make a 76 into a 73 could cause problems but you might get lucky. Adding a roll cage is no problem but changing the seats while not a problem with the TUV as long as they are TUV approved could negate any chance of getting an Oldtimer plate and the associated cost savings which are between 700 to 1300 USD on an old 911 a year
Old 10-15-2012, 09:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #395 (permalink)
jury's Avatar
In preperation of installing the engine I decided to turn the car around ( its much warmer with the garage door shut )
This of course meant dropping it back on its wheels and wheeling it out...it also gave the opportunity to take afew pictures...
Spot the obvious continuity error...
Really need to get it finished now, because it is a pretty little thing.....
Chris
Old 11-19-2012, 09:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #396 (permalink)
SCWDP911's Avatar
Inspiring Chris - glad to see it is still in progress and you have made some good progress!
Shane
- 1984 928S
Old 11-19-2012, 09:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #397 (permalink)
sladey's Avatar
Looks awesome Chris - I especially love the grey wheels
The simple things you see are all complicated;
I look pretty young but I'm just backdated
Old 11-19-2012, 11:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #398 (permalink)
jury's Avatar
Old 11-19-2012, 11:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #399 (permalink)
PM sent about door strap.
Jack
Old 11-20-2012, 10:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #400 (permalink)
