Fritz Peyerl's Avatar
torque specs
I am in progress of mating my engine and transmission. I was wondering what the tourque specs are for the 9 M6X42 aleen bolts, which hold the pressure plate to the fly wheel
Old 12-08-2008, 04:00 PM
Browzer52's Avatar
Hi Fritz,how's things?Talked to you at Crown Isle(black 1986 930)Torque you are looking for is 10 ft lbs.Considering what you are installing, I would put a little blue loctite on the bolts so you can sleep at nights.
Regards Al
2009 Harley Davidson FLHRCI Road King Classic
1998 BMW 328i convertible
2012 Nissan Frontier Pro 4X
2011 Nissan Xterra(wifes car)
Old 12-12-2008, 01:05 PM
tourque
Thanks Al
All is fine in Alberta, I am nearly finished with my 72 911T. should be on the road when that white stuff ( snow) is gone and they cleaned the roads.
send me your e-mail and I will send you some reports I wrote for the local P-club.
cheers
Fritz
Old 12-12-2008, 01:50 PM
rsscotty's Avatar
Torque specs.
Pressure plate bolts should be 8mm , not the 6mm stated above, and you should torque to 18 ft. lbs. I have never seen one come loose, so forget the loctite.
Old 12-12-2008, 02:30 PM
Browzer52's Avatar
Torque on an 8mm allen head bolt should be about 18 ft lbs,using a dab of removable loctite adds a bit of insurance.
Old 12-12-2008, 02:48 PM
