torque specs
I am in progress of mating my engine and transmission. I was wondering what the tourque specs are for the 9 M6X42 aleen bolts, which hold the pressure plate to the fly wheel
Regards Al
1986 930 2009 Harley Davidson FLHRCI Road King Classic 1998 BMW 328i convertible 2012 Nissan Frontier Pro 4X 2011 Nissan Xterra(wifes car) |
tourque
Thanks Al
All is fine in Alberta, I am nearly finished with my 72 911T. should be on the road when that white stuff ( snow) is gone and they cleaned the roads. send me your e-mail and I will send you some reports I wrote for the local P-club. cheers Fritz |
Torque specs.
Pressure plate bolts should be 8mm , not the 6mm stated above, and you should torque to 18 ft. lbs. I have never seen one come loose, so forget the loctite.
Torque on an 8mm allen head bolt should be about 18 ft lbs,using a dab of removable loctite adds a bit of insurance.
