G50 coupler when engine dropping?
Hi guys about to drop the engine but worried about the coupler connection from the gearbox through the car, if I lower the engine will it jam in there?
Thanks! Spence
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
As you lower the engine you also have to back it out. It' a tight fit as you have noticed (yet another benefit of a 915). Go slow through the crucial bit.
As they say here in blightey....gently gently catch a monkey.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Thanks Jasper,
I was told I can drop the engine about 4 inches with a partial engine drop but it really doesn't make sense as you have to back the engine out a fair distance anyway. I spose there's no easy way to do this (removing the shift rod), I also haven't heard anyone talk about removing the rear sway bar that I'm pretty sure will be in the way when the engine comes down. Wish I could get my hands on the bentley manual! Not easy to come by over here.
if I remember correctly, put the trans in a gear that moves the coupler to the back of the car, then disconnect the coupler, you may have to move the rubber boot around to get in there, helps to have the inside panel off to look and see what is going on
There is a 13mm bolt that hold the coupler to the transmission. You can acess it from under the car if you remove it you don't have to fight with the coupler and everything will drop straight down not like the earlier cars where you have to bring it down and out in an angle.
Tony Proasi 1969S 1957 VW Pickup |
yes, if disconnected in the correct gear you can drop the engine straight down or very close to that
Any idea which is the correct gear to be in ? It seems like 1st , or one at the top would push it back.
![]() Cheers, Emerald
'88 911 coupe, Laguna Green Metallic (sold)95 993 Aventurine Green(sold) 97 993 C4S Vesuvius |
I can't remember which direction pushes the trans. rod in... if you take the inside cover off and watch you will see
I stand corrected - I did not know you could take the coupler off! My apologies for the bum steer.
No problem thanks for the help everyone, I have since had this site pointed out to me on rennlist by 'g-50cab', it should a sticky somewhere http://www.heinys.com/enginedrop/. Fantastic!
Throw it on the ground!
Great timing, thanks for posting the link. I'm planning a drop and swap on an 87after Christmas.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I did a 3.2/G50 drop a few months ago. The G50 coupler is a very tight fit through the hole in the tunnel. You need to drop the engine/trans down and also roll it back at the same time. Again it's a very tight fit but it'll go through no problem.
I'm pretty sure the rear bumper needs to be removed from the car to do this. I'm not 100% sure on this but I do know it makes it alot easier - especially if you're using jackstands and jacks to remove the engine/trans from the car. |
