How to red tachmeter
(1) or (2) is correct?
Thanks ![]()
Fat butt 911, 1987 Last edited by rnln; 12-15-2008 at 11:56 AM.. |
A.K.A. GOB Bluth
2 is correct.
Paul Misencik Huntersville, NC |
Paul,
Thanks for response. I also thought so, but I wonder why the first mark is bigger than other marks, below 1k. Should it be zero (0)?
Fat butt 911, 1987 |
A.K.A. GOB Bluth
Yeah, it is kinda silly. I guess since the tach really isn't going to show engine speed under 600 RPM with anything even close to accuracy, they just sorta combined the "0" and "200" marks and called it a day.
Agree, but then when people said perfect idle at 880. Is it (1) or (2) below? Or anywhere between there is perfect?
A.K.A. GOB Bluth
Well, the width of the needle is probably covering 120 RPM, you know? If the needle is roughly halfway between the two marks, that's probably about as accurate as you're going to be able to hope for. The tach isn't accurate to within 25 RPM or anything like that, and even if it were, you're not going to see it.
ok ok
Fat butt 911, 1987 Last edited by rnln; 12-15-2008 at 02:30 PM.. |
Member 911 Anonymous
#2, Between 800 and 1000 is 900. So right below will be close to 880RPMs for you
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
