Nice marmot.
O2 Sensor Relay + Freq Valve problems
My 82 SC O2 sensor relay is not behaving correctly and the frequency valve will not work.
I've tested with 3 different new relays with the same results. Also, the frequency valve and new O2 sensor are within spec. With the engine OFF. The relay gets voltage at terminal #30 (12.3V) and at #87a (12.3V). #87 gets nothing. With the engine RUNNING #30 gets 13.7V, #87a nothing, and #87 13.7V. And of course the frequency valve will not function. With the engine off, I use a jumper wire from #30 or #87a to #87. Freq valve comes alive. Drives beautifully. But when I shut off the engine the frequency valve stays on I have to pull the relay or the harness connector on the freq valve. To get the valve to function again, the relay needs the jumper wire. Any ideas on what is causing this?
Mike Dunn Daytona Beach, FL 1982 PORSCHE 911SC |
grateful user
u must use the correct porsche relay, those uni 5 blades will not work good, also, pull your seat and u will see your grounds for the lamda control unit, there are several, i clean my grounds with sand paper, and apply di electro grease.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Nice marmot.
Thanks. I'll clean those grounds up. I'm using a new Wehrle W. Germany relay that looks identical to the original Bosch, I thought that would work. I'll pick up an OEM one.
This is going to sound stupid...but does your dome light and clock work? The fuse that these items are on, also provides power to the lambda brain. So if it's bad, replace it.
Matt. 83 911SC 85.5 944 NA - Sold |
Nice marmot.
Lights work and fuse #18 is good. I opened up the brain, the board looks good and it's getting power.
hook the jumper to power with key on only, if you have to drive it until you get a decent relay.
grateful user
part # 821-951-253-m14...14 bucks from pelican
Nice marmot.
ahh, nice tip. I'll use this until the correct relay arrives. Thanks.
