Throw it on the ground!
Please help me find fuel leak.
To start, I have owned my 87 for 2 1/2 years now and have always thought I noticed a faint fuel smell in the cabin but have never found a leak.
Today, walking up to the car after work I noticed a very strong fuel smell as I approached the drivers door. Opened engine lid and smelled engine compartment - no fuel smell. Opened front trunk - no fuel smell. Back to drivers door - very strong fuel odor. Pulled car out of parking space and inspected pavement where car had been sitting since lunch - no fuel puddle anywhere.
Got home tonight, parked car in garage and went out to dinner with friends. Upon return, wife & I entered garage and she said "your car stinks - what is that smell?" The entire garage had VERY strong fuel odor.
Also, last night on the way home from work, the car seemed to idle a little rough at stop lights. Thought it was my imagination but now wondering if it may be fuel leak related.
I plan on putting the car up on jack stands tomorrow and inspecting the fuel lines. Any ideas suggestions on what to look for? Usual suspects?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 12-19-2008, 09:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Gas Cap Gasket?
The oder may be emitting through channel of the release cable for the gas cap/fill compartment door.
My 2 cents
'85 Carrera Targa
PCA/POC
Old 12-19-2008, 09:19 PM
Found my latest fuel tank leak on top of the fuel tank. The spare had rubbed through the tank and created a very small hole. Pull the spare. Earlier leaks were fixed by replacing the fuel hoses in the trunk.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 12-19-2008, 09:46 PM
al lkosmal's Avatar
It doesn't take a lot of gas to make a big stink, but if you can smell it walking up to the car and in the garage, it's leaking pretty good. Since you gave the engine compartment the sniff test, I'd check out the front end, starting with the fuel pump, pump fittings and the hose from the tank to the fuel pump.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 12-19-2008, 09:51 PM
I've owned my 87 for 20 years now. No leaks yet. I want to do my first engine drop soon to replace the fuel lines and a few other things. Just can't seem to find the time. If it would start leaking I could make it a priority.
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 12-19-2008, 10:06 PM
I've just had the engine fuel lines rebuilt on my replacement engine in preperation for a swap and have been wondering about the condition of the rest of the 21 year old fuel lines. No need to wonder anymore. Getting ready to put the car up on jack stands in a few minutes and start looking for the problem.
Mark
1987 911 Coupe
Old 12-20-2008, 04:44 AM
You might also look under the left front wheel well at the small hose connections from the gas filler tube to the vapor emissions hoses--could be leaks there that are only fumes--as well as the larger hoses near the front of the wheel well that go to the "collector" box. I assume your car has it at that location, but maybe not. If these hoses are cracked, you may smell fumes, buy you won't necessarily see moisture.
Also, the fuel pump connections under the steering rack may have connection problems, and it is in the general area of the odor.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-20-2008, 08:39 AM
I replaced both lines to the vapor recovery tank this spring.
Found dried puddle of gas on the garage floor (floor paint had bubbled and had strong fuel odor) under the fuel pump. Removed cover plate. Saw no evidence of any leak. Then started car and crawled back under - still no leak. Will no go take the car for a drive and observe upon return. Kinda baffleing.
I also removed the tunnel cover behind the seats and no fuel odor there (thank god - plastic tunnel line replacement sounds like a PITA)
Mark
1987 911 Coupe
Old 12-20-2008, 08:46 AM
Sounds like you're narrowing down the search. Don't know what your pump/line set up looks like but sometimes the rubber lines to the pump and tank return make sharp and short bends in the cramped area under the tank and steering rack which is a prime area for cracking. Good luck on the hunt, and report back your findings, please.
L.J.
Old 12-20-2008, 08:52 AM
Took car out for a spin and put it back up on jack stands. Fuel pump and associated connections are good. Problem is that I have a leak in the fuel tank. This section of rustproofing has been missing since I bought the car 2 1/2 years ago but I have never noticed this. The rusty patch was bone dry until I took the car for a spin and pressurized the tank. I guess I'll be ordering a new gas tank for Christmas! How exciting
Mark
1987 911 Coupe
Old 12-20-2008, 09:25 AM
DRACO A5OG's Avatar
Was the area without protective coat always that big? I ta appears the rust did not help matters either?
Going to check under my car and patch spray and exposed metal at the tank.
'85 Carrera Targa
PCA/POC
Old 12-20-2008, 03:33 PM
Yep, been like that for a couple of years. Has always bugged me. Now it's gonna bug my wallet!
Mark
1987 911 Coupe
Old 12-20-2008, 03:52 PM
