Free minder
Aurel's Avatar
Iphone Dyno results thread
I recently acquired an ipod touch and dynolicious, to try measure my acceleration and HP output on the recently rebuilt SC. I did not get a chance to do many runs, and my best 0-60 time so far is 7.58s, with a peak HP of 127 () calculated with a weight of 2590# and a drivetrain loss of 15% (both estimated). I wanted to share and see what others can get with this interesting software.
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 12-30-2008, 01:35 PM
Garage Queen
PorscheGAL's Avatar
That is the coolest thing ever. Is it an app you download off of itunes?
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 12-30-2008, 01:52 PM
Free minder
Aurel's Avatar
Yes, and it costs $12.99. There is another one called pocket dyno at $4.99. At that cost, I may go crazy and get both .
Old 12-30-2008, 02:25 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
RevLite is free I think. Haven't had a chance to try it though.
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 12-30-2008, 02:58 PM
efhughes3's Avatar
Hmmm......maybe you oughta talk to the guy who rebuilt your engine?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-30-2008, 03:02 PM
Unsafe at any speed
Nader's Avatar
It really takes a full second to shift gears? Is that a 915 thing?
87 Carrera Coupe
Old 12-30-2008, 04:35 PM
efhughes3's Avatar
All air-cooled p-cars benefit from a pause between gears, not necessarily a 915 thing. Each driver shifts different, and each trans has its own needs.
My question is: how sensitive and how fast is the accelerometer in an iphone? My guess is that these weren't criteria of the designers when they were working on it, but who knows?
Ed Hughes
2015 981 Cayman GTS
Old 12-30-2008, 05:05 PM
Free minder
Aurel's Avatar
Ed,
The i-phone did better than a G-tech, and the numbers are comparable to a static dyno. I posted some videos and comparisons in this thread: Anybody using dynolicious?
Obviously in my case, 127 hp is wrong. I don`t think I screwed up my rebuild so bad, and 7.58s for 0-60 takes more than that. The weight must be off, I forgot to add my own and I don`t know exactly how much my car weighs.
Old 12-30-2008, 05:12 PM
efhughes3's Avatar
Unless you entered the 2590 wrong, I don't see how it could be so far off? 2590 may be a little light, but you should be in the ballpark.
Ed Hughes
2015 981 Cayman GTS
Old 12-30-2008, 05:16 PM
Free minder
Aurel's Avatar
I had the drivetrain loss set at 0. I recalculated with a 15% loss, and a weight of 2760# (adding my own weight). That gives 150 hp. Still low, but I may not have pushed rpms high enough in third gear.
Old 12-30-2008, 05:30 PM
Free minder
Aurel's Avatar
Better run for HP
Here is another run, with a different approach: pushing third gear to the max, till the power actually dropped. Now, I get 202 hp with 15% drivetrain loss and 2760#. Not my best acceleration though, you can see I slipped the clutch in first.
Old 12-30-2008, 06:15 PM
Your best numbers should come in the gear with the closest 1:1 ratio from looking at your chart third gear maybe the one or likely fourth check your gear chart, what gear box do you have?
Old 12-30-2008, 06:37 PM
Free minder
Aurel's Avatar
915 with standard ratios, whatever they are...
Old 12-30-2008, 08:05 PM
Have you done something to lighten you car?
I think a 78 coupe is supposed to weigh 2700 without an air-conditioner. I suspect targa's might be more.
I went to the local dump/transfer station and got a prety good weigh in on my 85 coupe. It came in at 2800 lbs w 7&8/16" wheels.
Cool tool.
Old 12-30-2008, 08:22 PM
Detached Member
Hugh R's Avatar
I just bought my son an I touch, I think I'll order the software as you said Aurel for the price, I might buy both! Oh, I see it works on an IPod as well, sweet!
Hugh
Old 12-30-2008, 08:41 PM
Free minder
Aurel's Avatar
Cool tool.
I`ve got AC compressor, condensor and heater blower removed. If the actual weight is higher than what I entered, my HP numbers would actually be higher too. I have found theses weights in an old thread: The USA '78-83 911SC is 2756 lbs. curb weight and ROW model is 2601.
Old 12-30-2008, 09:04 PM
Detached Member
Hugh R's Avatar
A little help please.
I downloaded the application, I can see it on my computer as an application, but I sync my IPod and it doesn't appear. No applications section appears on my IPod. I restored my IPod to factory specs and I get the same thing. I try dragging the app. down to IPod and it gives me a circle with diagonal line through it symbol, like it doesn't like it. Any love here
Hugh
Old 12-30-2008, 09:39 PM
Free minder
Aurel's Avatar
It is an ipod touch, right? The other ipods don`t have an accelerometer.
I downloaded mine directly from the ipod with the app store icon, through my wireless internet.
Old 12-30-2008, 09:50 PM
Detached Member
Hugh R's Avatar
Thanks, it's just a regular IPod. I'll have to use my son's Touch.
Hugh
Old 12-30-2008, 09:56 PM
rlh930's Avatar
Dynolicious
Dynolicious at $13 is certainly cheaper than a G-Tech Pro at $299. Likewise, Greenfinder, even at $35, is way cheaper than a Sky Caddie at $399. A real money-saver, that iPhone!
Anyway, here's the first run for my (stock) '87 930. 5.5 sec and 285 HP is pretty close to what the owners manual claims. Dynolicious seems fairly accurate, all things considered!
Roger
'87 930
'73 911T
Old 12-30-2008, 11:42 PM
