| Registered Join Date: Jul 2008 Location: Franklin, Tennessee
				Speaker help.
			I have a an 88 coupe. I have been reading past posts via the search function, but can't find an answer. I am trying to update my speakers. The rears are Denon DCS-461, and I will probably find something similar. (suggestions?) The hard part is the front. It has two speakers in the door.   I am not sure if this was OEM, but it appears the PO replaced the large ones and removed the smaller ones. Is anyone familiar with these, and are there replacements that would pop into these frames. I plan on replacing the crappy blingy head unit in the future, but don't want to drop all the money at once.  I hope to have a nice system in the end, so don't want to short change myself now. Also, is it common to replace the old amp under the seat? It seems in one post I read, that they just bypassed it and went directly to a new head unit that had more power than the old head unit. This is a daily driver, and I enjoy my tunes, as well as the music of a flat 6. The wife just likes tunes  Thanks for any help. Cheers, Emerald
				__________________ '88 911 coupe, Laguna Green Metallic (sold)95 993 Aventurine Green(sold) 97 993 C4S Vesuvius | ||
|  01-01-2009, 03:54 PM |
| Registered Join Date: Nov 2007
			You might find something at midwestelectronics.com. I been thinking about upgrading my system. I have  read the Blaupunkt THX 462 speakers fit the rear speaker holes. Good luck
|  01-01-2009, 06:33 PM |
			Thanks for the link, I'll have to check it out. Hoping someone can share some insight in the small ones that are missing. I may have to go the component route. Thanks, Emerald
|  01-01-2009, 06:53 PM |
| Registered |
			Your new head unit will probably come with a built in Amp. You can remove the old unit under the passenger seat, and use this as the junction point for the speaker wires.
|  01-02-2009, 02:58 AM |
| Used Up User |
				__________________ '87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- | ||
|  01-02-2009, 03:45 AM |
			Thanks for the input. Thanks for the heads up Newsboy. I am planning on replacing the head unit, and simplifying things will be nice. Nice system imcarthur, not sure it fits my budget at the moment, but very nice still. Cheers, Emerald
|  01-02-2009, 04:57 PM |
| Michael Delaney wanna-be Join Date: Jul 2005 Location: 1K Oaks, CA
			Here's the link for creating speaker adapters for a 6.5 speaker in the front doors (if  that's your inclination).. Mounting door speakers. As for the tiny tweeters in the doors, I got a pair of Polk Audio tweeters (sorry...can't remember the model) that literally pressed right into the factory mount like it was designed for it. As for the rest of your components, I'd just start searching the threads with the keywords: speakers amplifiers head unit There is a ton of info on this board, it just takes some creative searching to find it at times.
				__________________ 88 Carrera Cab C.R.A.P. Gruppe Member #7 | ||
|  01-03-2009, 01:36 PM |
| Registered | Quote:
 +1 on that last comment....just get the beer and plan on it. Best, Doyle
				__________________ Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia | ||
|  01-03-2009, 05:03 PM |
			Thanks for the tip on the Polks. I decided to take the small mounts out, and sure enough they have a 911 part number on them. I figure I will carry it with me to a stereo shop and see what fits. The search helps, but it does take some creativity. Sometimes I get lots, other times, not so much. The Focals seem popular and a good speaker. Maybe someone has adapted a set of 165's to the existing factory two grill setup. Cheers, Emerald
|  01-03-2009, 06:21 PM |
