sean m's Avatar
Pertronix help.......
First of all......I've done the search and read the posts (most were on the wiring of the unit).
I'm replacing a Pertronix ignitor. A wire from the previous unit had rubbed against the bottom of the rotor and pulled from the Pertronix.
Ordered the unit for my car ('77 911S) from our host. I followed all the instructions.
Anyway, car fires right up, idles OK, but runs awful......feels like I'm in 5th gear starting up a hill.
What did I do wrong on the install?
Is the unit bad?
Is this just timing? I've never set the timing. I guess I'm hoping this is the problem so I don't keep thinking I've installed incorrectly or it's a bad unit (which in my search has shown that there are several bad units).
Just wanted to check with the experts
Any help is appreciated.
Sean M
'77 911S Targa Ice Green
Old 01-02-2009, 02:01 PM
the timing gets changed when you move the box around for distance adjustment.
... this assumes it's wired correctly
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-02-2009, 03:30 PM
sean m's Avatar
Thanks Ronin.......I assume it's wired correctly since I simply replaced the previous unit.
Sean M
Old 01-03-2009, 05:33 AM
kodioneill's Avatar
they are total junk. put in points!
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-03-2009, 06:25 AM
Air gap is super important!I set mine at 30 . Make sure there tight as well a lose trigger can cause lots of grief.As said timing will change with the air gap.
Old 01-03-2009, 09:14 AM
sean m's Avatar
Hey tooth........I used the clear plastic feeler gauge they sent with the unit. I think its .30 mm.
Sean M
Old 01-03-2009, 09:35 AM
some pelicanheads report that if you leave the ignition switch to "on" without the engine running you can destroy the Pertronix.
I never read any other hard info. With that in mind I wired it through a connector block so I can just unscrew a terminal easily.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-03-2009, 10:04 AM
