Pertronix help.......
First of all......I've done the search and read the posts (most were on the wiring of the unit).
I'm replacing a Pertronix ignitor. A wire from the previous unit had rubbed against the bottom of the rotor and pulled from the Pertronix. Ordered the unit for my car ('77 911S) from our host. I followed all the instructions. Anyway, car fires right up, idles OK, but runs awful......feels like I'm in 5th gear starting up a hill. What did I do wrong on the install? Is the unit bad? Is this just timing? I've never set the timing. I guess I'm hoping this is the problem so I don't keep thinking I've installed incorrectly or it's a bad unit (which in my search has shown that there are several bad units). Just wanted to check with the experts Any help is appreciated.
Sean M '77 911S Targa Ice Green |
the timing gets changed when you move the box around for distance adjustment.
... this assumes it's wired correctly
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks Ronin.......I assume it's wired correctly since I simply replaced the previous unit.
they are total junk. put in points!
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Air gap is super important!I set mine at 30 . Make sure there tight as well a lose trigger can cause lots of grief.As said timing will change with the air gap.
Hey tooth........I used the clear plastic feeler gauge they sent with the unit. I think its .30 mm.
some pelicanheads report that if you leave the ignition switch to "on" without the engine running you can destroy the Pertronix.
I never read any other hard info. With that in mind I wired it through a connector block so I can just unscrew a terminal easily.
