70 911 Turn Signal Problem
HELP!!!!!
I'd appreciate any guidance from you early 911 Porsche Pushers.........
My flasher switch/relay is clicking when I use my column turn signal but I get no outside turn signal when I have it going left, the inside indicator works........when I have it going to the right I get no inside indicator light but my outside lights work.
I've got a new switch/relay but everything else is as built.........before I tear the whole thing apart and go on a wiring diagram adventure is there another relay or connection point that I should check.
Dirty Marty
Fallbrook, CA
[img]
Old 01-05-2009, 09:52 AM
Band.
It's possible you may need to open up the signals themselves and clean/burnish the bulb sockets and contacts. They get dirty and you'll spend forever chasing wiring and stuff all the way through the car and find out it was a bulb socket.
Take the bulb lenses off, and get the signal stalk on "left" where it's working inside. Then get out to a bulb and jiggle and turn just a little bit. It's possible you may get a bulb to start working and that's an indicator that the sockets are dirty.
All this said, the steering column switch is known to get worn out and need replacing.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-05-2009, 01:18 PM
