Question Install issue of M&K muffler
Received my M&K 1 in 1 out muffler today which I purchased from our host. I bolted it to my Fab Speed Cat bypass with no problem. I am having no luck getting the circle clamps that came with the muffler installed. One of the clamps is slightly bigger than the other. They seem to be short as I cannot get them to connect. Any advice is appreciated. 1987 911 Targa.
Old 01-09-2009, 11:21 PM
User
ikarcuaso's Avatar
You can't clamp either one, even the larger one? Ben told me the small one for an SC, big one's for a Carerra), and that it's OK to use just one. I used both anyway.
Yes, pics would help. You can also call Ben. He's very helpful.
82 Targa
Old 01-10-2009, 12:24 AM
can you read me the numbers off of the clamps? I susppect someone put the wrong clamps in the kit, I will send you the correct ones right away if thats an issue
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-10-2009, 03:44 AM
250 127/ 861 and 250 135./860.
Old 01-10-2009, 07:47 AM
deshetlr's Avatar
If Ben finds the clamps are correct I suggest 3 things. First do not snug down the bolts to the bypass until everything is loosely installed. Second, the T mounting bracket is adjustable so loosen it as well and try again. Finally I had an aftermarket system on before the M&K and whoever installed it bent the T bracket so I also had to remove the bracket, straighten it out and re-install. Once everything is installed then snug down the bypass bolts and then the clamp.
Scott
'86 911 Carrera Coupe, PCA, PBC
Old 01-10-2009, 08:04 AM
longer bolts?
206 637 4071
Old 01-10-2009, 08:08 AM
I was able to used the larger clamp closest to the exaust outlet and looks as if its going to work.
Old 01-10-2009, 09:05 AM
rhymes with targa
Bearded Viking's Avatar
Yep, that's what I did too. One clamp. It's been on for a few months now. No problems.
You're gonna dig the sound!
Old 01-10-2009, 09:09 AM
Yes the 135 is all that is needed in some applications the 127 is required but typically not. I like the 135 without the spring that way you have a bit more room
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-10-2009, 09:41 AM
plug&play's Avatar
I just installed just installed an M&K on an 87. It also came with a 127 and a 135 clamp. I put the 127 on the passenger side of the muffler. It was a tight fit. The 135 was too big to clamp down. I looped it across the flange on heater pipe crossover that lined up with the muffler bracket. Don't know if this is correct, but it seemed to work.
Tony
-- 87 911 Targa (Diamond Blue Metallic) 'Boxer-2'
-- 04 BMW R1150RS (Gray & Bavarian Creme) 'Boxer-1'
Old 01-10-2009, 02:07 PM
yup thats correct it just needs to stop any rattle between the 2 pieces
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-11-2009, 02:32 PM
On my car, the furthest one in the picture is the larger one, and wraps around the muffler AND the heater crossover pipe. The one closest should be the shorter one, and wraps around the muffler and the muffler to chassis bracket.
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 01-11-2009, 02:36 PM
