Head studs, by the sound of it. What year car?
Tony G 2000 Boxster S |
3.4 Bigger is better
Ditto on what tony said. That means at least a top end rebuild with steel studs. Picture of broken studs
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Senior Advisor
bummer time for a top end!
08 Cayenne Turbo |
Thats what I figured it was. I was just hoping someone would have tried to fill my head with happy thoughts and joy joy feelings and it would be something extremely simple. Well I guess I will start the process and get the engine out and get it tore down. Thanks everyone for the help.
Senior Advisor
the bright side is you will have a great running engine and get to see how everything works!
08 Cayenne Turbo |
Look into this further, I am not sure but sometimes some head studs can be replaced w/o a rebuild.
Happy thoughts: You really get to know your engine. The rebuild process is one of the best exercise you can do for yourself. The timing process of the engine is the most satisfying step a builder can have. And when you are done, you too can call yourself a Porsche expert.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
If you havent upgraded to the new valve stem seals you might as well do that while you have it apart....
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
I'm thinking this might be a good reason to convince my wife to let me build a hotter motor. I just have to find a way to justify it. LOL.
Max Sluiter
You need to go faster to keep the engine and head studs cool so they will not break
![]() More engine = more power = more speed (good)
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
pcar, do some research on this. Your "top end" can easily reach 3K, and double that if you decide to put in new P/C's. How good does the car run? What are the compression numbers? You didn't say what year your car was, but it sounds very much like a 3.0.
As mentioned, you may be able to get to these w/o a complete tear down. with 4 broken, your driving days are limited and you might want to drive it fairly easy. However, if this isn't your daily car, you may be able to drive a few weekends this summer. You don't say where you live either, so the over-the-winter thing might not mean anything to you. As far as "justifying," making a simple budget might throw up some red flags. That's why I suggested the research. Be prepared and be prepared to go over budget. |
The first signs of the dreaded "while you are in there" disease are showing. Run Forest, run.......
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
'80SC ROW '76S Wide Body '87 G50 Coupe '69T Bahama Yellow |
Did it once on a 2.8 twin plut I convereted from carbs to MFI. Timming the cams was not that big of a deal and I had never done anything like it before.
You can do a top end for $1,000 if you don't need to replace too many valves. And if the labor is free.
You could even re-use gaskets and seals......anything is possible but why cut corners. If you do a top-end you would want to replace the valve guides. And that means farming out the heads for machine work and valve grinding. I would also recondition the rockers.
Any good machine shop will tell you which valves are reusable and which need replacement based on the valve and stem condition. Usually the exhaust valves are suspect due to the higher stress from heat. I'd budget for a gasket set, all tune-up parts (oil, plugs, cap, rotor, chain ramps) machine work for the heads and rockers and valves. Have the cams inspected and make sure there is nothing wrong with the rings, ringlands and cylinder walls. You never told us how many miles are on the engine and if there is smoke at start-up or decel and what its oil pressure and oil consumption is. These factors would help deciding what else is indicated. A mild upgrade could be to get a different cam grind if the cams need work anyway. Then it's almost free of charge. Ingo
