No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Noob question
Why there isn't a replacing wheel bearings project in the 101 Book?
My left front wheel has developed a rhythmic knocking when the steering wheel is on "hard turn". The Bentley's suspension troubleshooting suggest wheel bearing's replacement. How hard is this job?
I already ordered new wheel bearings. Other than tools, what else am I going to need?
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-18-2009, 09:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Replacing Bearings is not the only thing, per Steve Alarcon, Johnson's Alignment.
You will most likely have to replace the inner bearing hub, they tend to wear out. But you have press them in.
I have the same issue on my driver side wheel. Try to tighten it first to see if that will help. Do a search it is very easy to do.
After adjustment driver her around and then stop and put your hands on the tire from the inside and pull several times. If you don't hear a click you are good to go.
'85 Carrera Targa
PCA/POC
Old 01-18-2009, 09:31 PM
Thanks Draco, I will try adjusting it first, I hope that will take care of it. I surely don't want to replace the wheel hub.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-18-2009, 09:44 PM
DRACO A5OG's Avatar
No Problem Brother!
Do the adjustment when you car is cold, some have even placed their bearings in the freezer to shrink the metal. I haven't done this but did adjust when cold.
Bearing adjustment is recommended when you do oil changes.
If I may suggest get the Bentley Manual too, priceless
'85 Carrera Targa
PCA/POC
Old 01-18-2009, 09:50 PM
I already have the Bentley, it shows how to do wheel bearing adjustments, I will do that asaic.
thanks again.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-18-2009, 09:56 PM
DRACO A5OG's Avatar
Cool,
Strange but makes sense the left will get loose, the wheel turns mostly the same direction the adjustment clamp goes loose. Just my observation.
PAG did not think this one through.
I learned how to check the wheel for looseness by watching the speed channel and saw techs pulling and pushing on the wheels for loose bearings. fyi.
'85 Carrera Targa
PCA/POC
Old 01-18-2009, 10:04 PM
DRACO A5OG's Avatar
It is the Inner Race I believe not the hub.
'85 Carrera Targa
PCA/POC
Old 01-18-2009, 10:47 PM
SteveinTO's Avatar
If you ordered the bearings, or even if you just clean and repack the originals, you should order two wheel bearing seals, one for each side. To remove the inner bearing, you will pry out the grease seal from the hub and probably ruin it.
To clarify, if you replace the bearing, you should replace the race also. They're generally a matched set. The race is a pressed fit in the aluminum hub. You can beat them out with a drift & BFH, but I consider it more stylish for us effete, Porsche owners to gently press them out. It's not a Ford truck for Pete's sake.
The freezer part is for the new race prior to being pressed in. Putting it in the freezer for an hour will shrink it momentarily and make it easier to press in...or beat in with a socket and the ubiquitous BFH.
If you want to just try adjusting them prior to replacement, I don't think you need to freeze anything for that. 'Course if you're in the mid-west, just work in the drive-way and eliminate the fridge altogether.
Anyway, dive-in. It's pretty basic auto mechanics and there's alot folks here to help.
Old 01-18-2009, 11:35 PM
Steve,
Thank you for helping me.
So, I need to buy 2 of these seals also? Pel part # 477-405-641-M204
What's the Pel part # for the race's, I can't find them?
There's a part for removal of the rear wheel bearings, how about the front ones, what can I use to press them out properly, don't want to go Cromagnon on them.
What is BFH?
(I'm subscribed to this thread: Acronyms, Abbreviations, Technical Terms & Jargon
Milt mentions BFH but he never tells what it is?
from steve
I'm in the northeast, still pretty cold, not as bad as last week though.
Thanks again.
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-19-2009, 08:41 AM
Poor-sche Lover's Avatar
BFH is a big f---ing hammer!!!
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 01-19-2009, 10:26 AM
gtc gtc is offline
abides.
gtc's Avatar
The bearings come with races. So for each front wheel you will need one inner bearing, one outer bearing, and one seal.
Some suggest replacing the spacer ring (maybe what Steve is referring to as 'races'?) and it's O-ring also, but they are more difficult to remove from the spindle. Mine looked ok, so I left them in place when I did my wheel bearings.
Graham
1984 Carrera Targa
Old 01-19-2009, 11:17 AM
Thanks for the definition Poor-.
gtc, if you don't mind me asking, what tool did you used for getting the bearings out of the hub and for pressing them back in?
thanks
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-19-2009, 12:28 PM
So, I've searched the forums for wheel bearing replacements and I read most of the threads that resulted from my search. I understand the process and I'm aware of heating the hub and using a press to remove the bearings and reinstall them. Since I'm still not sure if I have to replace them or adjust them, I will try the latter first, even though I already ordered the parts. I'll replace them if I have to. Anyway, I jacked my car today, place the stands and took off the wheel. I have to be honest here, as soon as I saw the grease cap I froze, even if it's only 34f outside.
How do I get the grease cap out without damaging it?
Using bare hands I tried to unscrew it, nothing happened. Then I tried pulling it, but it won't budge.
Can someone help me on how to make it come off? I would like to adjust this immediately.
thanks,
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-22-2009, 12:07 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
They make a tool for removing the cap but using a blunt end punch you can tap it with a hammer going to opposite sides and it will work it out. Some use a large set of channel lock pliers and wiggle them out, just don't do anything hard enough to dent the crap out of them. The races will be a lot harder to remove and install. Once you get the hub off the outside bearing will fall out then you need to remove the inside seal to have the inside bearing fall out. Now when you look inside the hub the races for both are (pressed in) the hub but there are opposing notches in the hub so you can tap them out with a punch. Pretty basic and once you do one you'll do the others in no time. If your still confused at this point try to get some help so you can see how its done on the first one. Installing the new races (and don't put new bearings in with the old races still in there) is a little more tricky and the seal can be real challenging because they distort very easy. I always buy at least on extra seal just in case. Be very careful because the hub is cast aluminum and can distort easily, new they cost a little over $300. each if you can still get them. I've done many bearing and race replacements on other cars/trucks but my Porsche was a bit of a challenge because of the aluminum hub.
Old 01-22-2009, 12:27 PM
I use 2 hammers, wear eye protection:
Place claw of 1 hammer on the cap edge, hammer face pointing up. Strike hammer #1 with hammer # 2. The curve of the claw on hammer # 1 is a natural for helping change the direction of the force. turn the wheel, doing this in a couple of places.
The cap should pop off easily.
Note--two hardened steel surfaces coming together is generally a bad thing, don't use a lot of force and wear eye protection.
O'Neal
PS Did eye mention to wear eye protection??
Old 01-22-2009, 12:54 PM
kodioneill's Avatar
when you are ready to install the bearings you must pack them with the proper grease. acquire some wheel bearing grease from the parts store it doesn't matter what brand no matter what anyone says. put a small amount amount of grease ( a tablespoon or so) in your left palm then holding the bearing in your right hand between your index finger and thumb push the grease through the SIDE of the bearing parallel to the rollers until it goes across the entire surface and through the other side moving around the entire bearing. then spread the grease around the bearing roller surface for good measure.when you tighten the bearing get it snug then while turning the hub LOAD the bearing down somewhat tight. then back off the collar slightly. if you make it to tight (the collar) the bearing will fail. you should be able to move the washer under the collar with a screwdriver blade with a little force. it takes some time and experience to feel the proper torque.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-22-2009, 01:06 PM
AutoBahned
RWebb's Avatar
yes the cheapo lard base grease is just fine!!
if you are going to this much effort - and if it lasts many many years -- why not use something good??
Old 01-22-2009, 02:09 PM
kodioneill's Avatar
i believe anything that a napa or autozone offers as wheel bearing high temp grease will be fine. not lard for chicken frying. a little critical perhaps.
1982 chiffon 911sc
Old 01-22-2009, 03:29 PM
AutoBahned
RWebb's Avatar
nice Golden...
but why not spend another buck for Synpower or something similar?
Old 01-22-2009, 05:09 PM
Thanks guy's,
Well, I failed again. I tried using one of those rubber head hammers and hitting that one with another hammer, it did not move. The rubber hammer it's too big to fit in the right angle. I guess I need something else. I will check the local hardware store to see if they have anything that might help get this cap out of there.
Also, I noticed that when I was tightening my lug nuts the movement of the wheel while applying heavy force produces a small "ticking" sound, does this mean that adjustment is out of the question, and that the bearings are kaput?
RWebb- Where can I buy that Synpower, do pep boy's carry these?
The Bentley say's lithium based grease and they have that at the local pep boy's.
thanks
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 01-23-2009, 11:05 AM
