Johnb911's Avatar
First Engine Drop Question
I'm a little confused especially after I just red the thread about separating the Trans and Engine.
Is it not easier to drop the whole engine and trans as one unit and leave it together if you are not putting it on a stand.
And if you are putting it on a stand would it still not be easier to mate the two while they are out, then when you are trying to raise the engine back into the car?
I ask because I want to do Valve adjust, egine clean up and clean up the Engine bay all at the same time.
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 01-21-2009, 04:40 PM
Yes, and yes, Drop and install both at the same time. The tranny separation thread poster is a first timer and he is reluctant to apply force where it is required. If all the bolts are off, and it separates 1/4inch, then a pry bar will do the rest.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-21-2009, 06:23 PM
Band.
Do them together, if for no other reason than you will learn more that way.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-21-2009, 06:26 PM
sudo apt-get purge 930
equality72521's Avatar
Yes on all questions.
--clutch-monkey
Old 01-21-2009, 08:38 PM
Recreational User
porschenut's Avatar
I haven't done it yet, but more people have told me to take them up and down together than the other way around. I'm guessing it would take an extra jack under the tranny to do this.
Old 01-21-2009, 09:04 PM
+1 on dropping both at the same time. I've done this several times in my garage using two friends and two jacks. I also strongly recommend taking off the rear bumper so you don't have to raise the car so high to slide the engine out.
1986 Carrera Targa - sold
1987 Carrera Coupe - sold
2003 Twin Turbo - sold
964 Coupe - on the hunt
Old 01-21-2009, 10:11 PM
Mitch Leland's Avatar
Engine support...
You only need one support under the engine and trans. Everyone has their own favorite way of supporting the engine and trans. I cut up a piece of 3/4" ply that fits between the trailing arms and carriage bolted a 1" pipe flange to the plywood. The pipe goes into my floor jack receiver. I wedge a couple of 2X4 blocks under the heads to balance the engine and that seems to work pretty well for me.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 01-21-2009, 10:20 PM
Somatic Negative Optimist
Gunter's Avatar
supporting engine at removal
Pictures show my "safe" set-up.
Ignore the bragging that it can be done in 15 Minutes.
I recommend taking the engine/transmission as one unit and I recommend to do it in a safe manner.
Reading the Bentley beforehand helps. I remove the muffler but not the bumper.
Use 4-5 ton jack stands under the T-bar covers because they have a wider base than 2-3 tons. I use 2 small floor jacks on the sides and 1 large floor jack for the actual lift.
Make sure you put large wedges (Choke blocks) under the front wheels before you lift. Disconnect the battery!
Get a jack that has a lift height of at least 22", don't worry about the range because you can pre-lift the car with jacking plates in the square holes under the doors.
Instead of jacking plates, I use regular 7/8" key stock 6-7" long with a ¾” nut welded on the end for the smaller floor jacks, one on each side.
Pre-lift the car a little at a time, place the wide-base stands under the T-bar covers.
Heights required: 32.5" from floor to underside of bumper will clear the engine to be rolled out on the floor jack. To obtain 32.5", I found that the T-bar covers will be 23.5" off the ground resting on the 5-ton jacks: VERY SOLID, plus the Bottle Jacks on the sides!
Center the large floor jack on the engine seam; the "Sweet spot" for balance is in front of the sump plate, NOT ON IT!
I made a plate from ¾” plywood with cut-outs to support/balance the engine/transmission on the jack; you can make one or buy the steel plate from PP for this.
For maximum safety, aside from the jack stands under the T-bar covers, I place bottle jacks under the 7/8" key stock in the square holes meaning: I have 2 jacking devises per side supporting the car. Push the transmission input shaft into 1st or 3rd before lowering. (Easier for the shaft to clear the hole when lowering)
After you disconnect all the wires/hoses (Take pictures) the lowering is easier if someone holds the engine/transmission for balance. You can do it alone if you use pieces of 6x6 and 2x4 for support under the HE's and come down in stages. Take it slow and watch for things still connected.
Key Stock: 7/8” x 7” with a ¾” NC nut welded at the end and a ¾” x ~2” NC bolt.
Items to disconnect or remove when removing engine/transmission:
1. disconnect battery in front trunk. Shift into 2nd or 4th.
2. shift-coupling and speedo wires. Push transm. input shaft into 1st or 3rd.
3. transmission to body ground strap.
4. throttle linkage.
5. clutch cable (also remove fabric strap holding clutch cable off throttle linkage). Clutch levers off cross-shaft, C-spring.
6. Reverse gear wires.
7. fabric strap holding parking brake cables.
8. fabric hoses from heater box outlets to heater valves on body.
9. starter wires.
10. CV joints at transmission output flanges; tie axles up out of way if you do not disconnect wheel side CV joints.
11. soft S-hose from engine mounted oil cooler to oil tank
12. hard oil line from engine to oil filter console; disconnect at console.
13. air filter, air cleaner and associated parts.
14. 14 pin connector
15. connectors/wires to ignition system
16. fuel lines (be careful with any plastic tees or other fuel line fittings; they're hard to replace OEM parts)
17. breather hoses from oil tank.
18. anything else connected to engine (hoses to charcoal cannister?)
19. after supporting engine/transmission; transmission mount screws and rear engine mount bolts
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-22-2009, 09:08 AM
Tired Member
DaddyGlenn's Avatar
Here is my first engine drop thread:
Here goes...1st Engine Drop
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-22-2009, 09:16 AM
vash's Avatar
drop both. take care of all the clutch arm stuff while everything is still in the car. much easier than trying to reach under a furniture dolly to disconnect it.
poof! gone
Old 01-22-2009, 09:38 AM
