Banned
marelli rotor questions
hello
Have a 70T with the marelli dizzy , i was wondering if anyone has a rotor for the 70T i have a 69 marelli rotor that installs but quickly noticed that the cap was to high and the rotor was not making contact inside with the cap contacts about 1/2 inch to short was the 70 rotor taller rotor then the 69 rotor , also does anyone have a rotor or know where i can get one thanks |
Parts for these are few and far between. Sorry my response doesn't answer your question, but I wanted to suggest that you start a search in ernest for the Bosch replacement.
pozee |
Banned
which bosch distributor will work with the 70 911 2.2t
RETIRED
Yup, where are ya located?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Banned
i am in CT
RETIRED
I have an early 2.0 motor that was rebuilt to "S" specs, I found an early Bosch dizzy that worked on eBay. I would ditch the Marelli.
Mine is in a 914/6.
For the '70 2.2
Bosch JFDR6 0231 159 008
pozee |
RETIRED
Yeah what he said....I had to go look up my notes....too many cars....
find a 2.7 unit, disassemble and machine down to the dimensions of the early unit.
Banned
thanks , looking for ASAP install, either a short cap marielli , tall rotor marelli , or
a drop in bosch dizzy , where is the best place to purchased a rebuilt bosch 0 231 159 008 pelican is outta stock |
RETIRED
evilBay or talk to someone on the Early S registry.
