Knock control should only be a safety net, a well tuned engine should not hit the knock limit while running even at WOT. If a EFI system hits knock it normally simply pulls ignition out and this yields to less than best max Torque. A good Tuner looks for knock to stay away from it, they should not tune a engine intentionally to hit the knock limit.
Also worth mention is that a tuner looks at several factors for IGN. For example most EFI systems have ign compensation tables for IAT and CHT, as either of these increase the maps pull ign out as well. Knowing howto properly set these allows a engine to run more ign adv if IATs are cold, like in cold Winter weather. It is very dangerous to tune a engine in cold weather and not understand these concepts, this is a major mistake made by first time tuners.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Of course, there are other ways to do this. I came up with an elegantly simple method over twenty years ago. Tippy: It sounds reasonable that an air-cooled engine would be noisier than one cooled by water, but that is not the case. The SafeGuard has no problem working on VW, Porsche, or Corvair. Partial list of some on pelicanparts that are using it: spuggy Nize Steve@Rennsport Cloggie smurfbus sjf Louie928 Last edited by John at J&S; 05-09-2012 at 04:04 AM.. Reason: spelling |
Subscribed
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Chain fence eating turbo
I run low-15 AFR's at cruise easily. It's not until I see low to mid-16's before I get lean surge. Might be I get away with it due to pretty advanced timing at part throttle.
I would rather be driving
Yes, If you can not advance timing, your call will be unhappy under lean conditions.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Subscribed
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
Happiest when Tinkering
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
This is an excellent article written by OEM engine management expert (Allen W. Cline) in Detonation and Pre-Ignition I thought folks may enjoy the detailed read:
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline This article explains Detonation and Pre-Ignition in very clear easy to understand terms. Pay very close attention to his points about Cyl Temps throughout the article because in our air cooled engines these tend to rise extremely quickly. You'd be very surprised to learn that CHTs rise very quickly without being at WOT. The biggest offender is lugging a 911 engine, where lugging is a term meaning that you are applying moderate to heavy load at low RPMs like 4th gear at less than 2500RPMs. I have a CHT monitoring system in my 3.2L and you can see CHTs rise amazingly fast under this condition especially in HOT 90F+ weather. Do this to our motors then pull a WOT run and your in big trouble! I never run my car below 3000RPMs in hot weather.
Yep, I've done that!
X Load/Y RPMs = load per revolution Good stuff!
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
Very interesting article. Thanks
I am nothing but a rookie that wonders, but here goes... On the turbo side of the pelican forum, there has recently been a thread about auto tune features in modern efi systems, and wether this is possible or not. My question is regarding ignition timing and tuning. Wouldn't it be possible to use a combustion pressure sensor, I.e. one of these: https://www.avl.com/pressure-sensors-for-combustion-analysis Based on the peak pressure and cam/crank position sensors, have the efi adjust ignition timing so peak pressure occurs at 14 degrees after tdc, optimum?
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk Last edited by jsveb; 03-04-2013 at 07:19 AM.. |
The other much more dangerous issue is that peak torque can't always be done because detonation prohibits it. In the past I've also mentioned how important it is to understand the effects IntakeAirTemp has on peak torque. A common mistake is to tune on a cold 30F day, dial in WOT ignition and call it a day. Huge mistake! The ignition values that can be used with cold IATs won't work once IATs get hot like 90+F! Good ECU systems have IAT and CHT Ignition comp tables, the stock DME has these built in. Knowing howto properly setup these tables can really help get some extra torque at cold temps. But you must dial back ignition as IATs and/or CHTs rise.
Wouldn't the pressure sensor also be able to pick up detonation? Not only would we be able to see an abnormal rise in pressure, but it could also be identified as being "out if timing" when analyzed in relation to cam timing etc. together with regular knock sensing this would further protect the engine as well.
I am not a proponent for complete autotune, I just find this an interesting discussion enabling me to understand a little more based on your feedback - thanks.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
This would be cool to transfer to a 911:
Trionic - Wikipedia, the free encyclopedia
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Very neat article - thanks!
For the tuning crowd. why not just install a knock sensor? After all, that's what all the OEMs currently use. There are a few reasonably priced aftermarket knock sensors available.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
I would love to have a knock sensor and MS II has the capability to use one but it takes an amplier that cost more than my entire ECU to make it work.
No affiliation, don't currently have one installed on my car, though I intend to do so and then get a SW chip. Price is not unreasonable, internet search suggest it does what he claims it does.
J&S Electronics SafeGuard Indivdual Cylinder Knock Control
