is there a website to decode my VIN?
is there a website where I can decode my VIN number?
I would like to know its original color? both inside and out? It looks like its an ROW just want to find out for which market it was made? it also has no SUNROOF, I want to make sure it was like that from the factory and if so, how many were made that year with that spec? I would like to know if it came with no A/C from the factory...stuff like that... can anyone of you expert Guru's help? my VIN number is 91A0134256 Thanks alot!
Domino ![]() 2022 BMW X5 1971 Porsche 911 3.2L hotrod 1970 Ford Bronco 4x4 1962 VW Crew Cab truck |
You can't tell all the stuff you wanted to know by the VIN. A certificate of authenticity from PCNA may give you a pretty good clue how your car was equipped originally. COAs can be very accurate or have some mistakes so don't take it as gospel. I believe PCA also publishes a similar book to the Red Book for about $7 shipped if you're a member.
1982 911SC 1987 924S Last edited by rbuswell; 01-24-2009 at 08:05 PM.. Reason: spelling |
Does PCNA or PAG give the engine's output numbers if requested?
jp |
wow!! good stuff....thanks alot....that is a good start!
I appreciate that! Domino
1982 911SC 1987 924S |
The factory spec booklets contain an engine type decoder for the motor serial # and the published power outputs for that motor type.
'77 S with '78 930 power and a few other things. |
No sunroof is good...you just gained over an inch of headroom, and saved 40-50 pounds of weight...weight up high, where you need it the least.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Try this:
http://www.0-100.it/porsche/chassis/chassis_ital.html It's in Italian, but it's kind of possible to get the meaning anyway.
/Nimskov |
No sunroof is definitely good, if I could go back in time, I would've made it option delete.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Monkey+Football
You've got a ROW engine, and its number 4256 of 4831 A program 1980's built.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
that was a really nice website! thanks for sharing...I also looked at the Italian one, but the second one is a little more usefull....it has everything the italian website has, and a little more!
great stuff on both! thanks Domino
