New oil cooler running hotter than trombone
I was running between 190 to 200 degrees with a trombone oil cooler on my 75 911S. Switched to a brand new carrera style oil cooler, now the car runs a constant 210 degrees under the same driving conditions. Do guys think I need to run an electric fan to bring the tempature back down?
1975 911S Peru Red
1972 Datsun 240Z Turbo
2006 Subaru WRX
1984 300ZX Turbo
2000 Infiniti G20T
Old 02-03-2009, 08:53 PM
Administrator
Jack Olsen's Avatar
A Carrera cooler should definitely cool things more than a trombone. A fan is there to help when you're stuck in traffic.
I'd want to make sure there isn't an obstruction inside the line or the cooler -- or that the thermostat is opening fully.
Old 02-03-2009, 09:34 PM
pwd72s's Avatar
I'm with Jack...my old S (factory radiator cooler) ran much (10-15 degrees) cooler on the same roads, same day, as a friend's '73 S that had the trombone cooler.
Old 02-03-2009, 11:36 PM
myamoto1's Avatar
+1 on checking your thermostat
Josh
85 M491 Coupe - "Fat Bastard"
Old 02-04-2009, 09:04 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
check the temps at the hard oil lines just before you get to the front cooler. a hand held infared thermometer works just great.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 02-04-2009, 09:12 AM
Black and Blue
Kemo's Avatar
i dont know of a good test to insure that the thermostat is open all the way...
Kemo
Old 02-04-2009, 09:14 AM
myamoto1's Avatar
the quick "idiot test" I've used to check to make sure my thermostat is opening, is to feel the lines, in the front fenderwell. check both the feed and return lines, to see if you're getting much of a drop in temp.
Josh
Old 02-04-2009, 09:47 AM
if everything else checks out you need the fan in traffic. Does the temp drop on the hwy?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-04-2009, 12:38 PM
burgermeister's Avatar
By new Carrera style cooler, do you mean the late 80's style? Has a plastic cover to protect it from rocks & whatnot as well as any cooling air that might be in the wheelwell area. I believe the Carreras got a notch cut out of the front bumper somewhere around the fog lamp / turn signal area to allow some airflow to the radiator cooler.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-04-2009, 12:46 PM
Thanks guys for all the replies. Both hard lines are hot to the touch. I'm going to try to locate a hand held infrared thermometer to see what the temperature reading is. I'm going to try to figure out how to test the thermostat. Also the car is running a constant 210 degrees at highway speed without any traffic. Once again thanks for all the suggestions
1975 911S Peru Red
2006 Subaru WRX
1984 300ZX Turbo
2000 Infiniti G20T
Old 02-04-2009, 12:59 PM
It's an Elephant Racing wide mouth oil cooler with a stone guard and I'm also running an oil cooler air scoop.
1975 911S Peru Red
2006 Subaru WRX
1984 300ZX Turbo
2000 Infiniti G20T
Old 02-04-2009, 01:17 PM
Wasn't there an issue with a bad batch of oil coolers? I recall some were missing a baffle between the 'goes-in-ta' and the 'goes-out-ta' fittings. This allowed the oil to take a short cut back to the tank rather then go the long way thru the cooler.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Things to check..........
AD911,
A good Carrera cooler is sufficient to cool your engine. If the new cooler is actually hotter now (under similar condition as you said), I'll check the auxiliary thermostat first. It may take some effort to remove the auxiliary thermostat. You could test your auxiliary thermostat in an oil/water bath at 180°F or higher. This test will eliminate any quess work. Then proceed to investigate the new cooler.
When you are experiencing some low or high temperature problem/s, two things come in mind, thermostat and cooler (no liquid coolant in our older 911's). If the thermostat passes the test, then you know what's causing your high temperature. HTH.
Tony
Old 02-04-2009, 05:29 PM
Another test would be to put the trombone back on and see what the temps are with the trombone.
If it is a problem with the cooler, call Chuck. He's sold a lot of parts through Pelican and this board. He should fix it.
Matt
72 911T Targa - Sold
Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat.
Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!!
Old 02-04-2009, 06:25 PM
I believe the missing-baffle problem was with some wide, front-mounted, B&B-type coolers, not the fenderwell ones.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 02-04-2009, 06:37 PM
Send a message via AIM to fintstone
I have the same setup and mine runs at the same 210F. Doesn't sound like a problem to me...as long as it stays in that range.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 02-04-2009, 08:32 PM
SteveinTO's Avatar
I thought the missing baffle of three years ago or so was on the Carrera fender coolers. You could shine a light in one port and see it out the other. I think there was a baffle in there, it just didn't seal very well, allowing oil to not be forced through the cooler.
Old 02-04-2009, 10:38 PM
