AKA SportsCarFan
FastCarFan's Avatar
Whale vs. duck?
I have seen a lot of posts about whale-tails & duck-tails, but most are related to the appearance of the tails. I am curious about the relative effectiveness of the two tails.
I would assume that Porsche's knowledge base increased over the years & it switched to the whale at least in part because it is "better". Maybe it provides more downforce with less drag? Or the same downforce with less drag? That is what I would guess. Am I correct?
I realize there are multiple versions of the whale-tail, turbo vs. non-turbo, etc. I have an '88 Carrera with the optional whale-tail. If I switched to a duck-tail how would the performance of my car be affected? What about the weight difference between the two?
As always, thanks in advance for your replies. I know someone here has the answers to my questions.
Doug Miller
1988 Guards Red Carrera
Old 01-26-2009, 06:11 PM
AutoBahned
RWebb's Avatar
whale is better than duck - search on those terms for many lengthy explanations...
Old 01-26-2009, 06:14 PM
old man neri's Avatar
The better question is what kind of driving are you doing? Depending on the use of the car you may not notice any difference.
Old 01-26-2009, 06:40 PM
Also what car? Do you have a front spoiler etc.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-26-2009, 06:41 PM
AKA SportsCarFan
FastCarFan's Avatar
Fair question. Mostly weekend drives on winding roads through the woods, freeway trips to Mid-Ohio & about 4 track-days per year.
And I do have the front spoiler.
I will search. Thanks.
Doug Miller
Old 01-26-2009, 06:48 PM
Whale has less drag, weighs more. Both improve the aerodynamics in a big way.The duck looks better on the earlier cars. You need some sort of spoiler on the front to balance otherwise you'll get front lift at speed. If you can get a copy of Paul Frere's book all the aero figures are there.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-26-2009, 06:52 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
i doubt you will notice any difference....now if you paint your car blue....we all know how fast that color is.....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 01-26-2009, 06:54 PM
AKA SportsCarFan
FastCarFan's Avatar
I agree I likely wouldn't notice any difference. The question was more out of curiousity than an attempt to shave 2 seconds off my lap time.
And, no, I am not painting my car blue. Red cars are faster. Everyone knows that!
Doug Miller
Old 01-26-2009, 07:05 PM
Please read this. It might help you, it also has graphs showing the effectiveness of each tail vs speed.
Remember to thank Ian for his hard work
-matt
Old 01-26-2009, 07:53 PM
Doug&Julie's Avatar
Originally Posted by RSTarga View Post
Whale has less drag...
I could have sworn I just read an article that stated the miracle of The Duck is it increased downforce without adding drag...
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 01-27-2009, 04:01 AM
Matt's link is gold.
None of the Porsche spoilers actually creates any positive down force, they do reduce lift. At 60 it is not significant, 90 starts to do a little, at 150 the 3.3 tail reduces lift by about 250 lbs on a rear end that weighs about 1800lbs. A duck is about half that.
I do believe some of the spoilers do "spoil" the air flow and reduce drag to.
Old 01-27-2009, 07:08 AM
Bill Verburg's Avatar
It took ~30sec to come up w/ this thread using search "lift and drag"
Here are others
Bill Verburg
Old 01-27-2009, 07:24 AM
