Doumb Spark Plug Question for Early 911
I went to order a set of plugs for my stock 1973.3 (CIS) 911T. In the past I have used Bosch W5DC plugs with good sucess but decided to try the NGK's.
On speaking to the fellow on the order desk, he told me that he thought they were better and I should give them a try. I said ok and they shipped me a set of NGK BP5ES plugs. Looking at the NGK Web site, I am now confused if the correct plug was selected. This APPEARS to be a much hotter plug than what am am currently using. Anyone have any comments about this? Thanks!
Max Sluiter
I believe Bosch and NGK heat ranges are numbered in opposite directions. Bosch get hotter with higher number, NGK get colder with higher number.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The NGK 5's are too hot for your car. I would use 6's.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve,
That's what I was afraid of.
The NGK number is in relation to its heat dissipation capability, so the higher the number then the lower CHT. Looks like you already figured this out.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Carmagic.us
I was looking what tyle of plugs for my '71 911T and at the NKG site the
Standard is BP7ES and the Iridium IX is BPR7EIX http://www.ngksparkplugs.com/part_finder/car_truck_suv/results.asp The same showed also for the '73 http://www.ngksparkplugs.com/part_finder/car_truck_suv/results.asp I hope these links work.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
BPR7's in my 77. i just looked at them yesterday. they looked very good.
