e p slick's Avatar
OBD 1 and 2 When?
On which year model did OBD 2 replace OBD 1?
Thanks - EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 02-10-2009, 09:07 AM
Bill Verburg's Avatar
MY95 was the last for OBD1
MY96 was the first for OBD2
Bill Verburg
Old 02-10-2009, 09:15 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
Actually some cars had OBD2 in 95, but it was mandatory in 96.
Old 02-10-2009, 09:25 AM
onboost's Avatar
Both those guys are correct!
RGruppe #180
Old 02-10-2009, 09:29 AM
e p slick's Avatar
thanks
Thank you all.
EPS
Old 02-10-2009, 09:33 AM
Interestingly, I have a 95 Jag xj6 that has ODB 2, but the Arizona DOT smog checkers don't use it. It goes on the treadmill just like my 89 3.2
todd
89 Targa
Old 02-10-2009, 10:06 AM
signature65's Avatar
Just some trivia.....Porsche was the first company to ever use OBDI in the 80's
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 02-10-2009, 10:18 AM
This being the Porsche 911 forum, I stand by what I stated.
Just because a car has an OBD2 plug doesn't make it OBD2 compliant. Yes, during the MY95 993 run they switched from the round OBD1 plug to the trapezoidal OBD2 plug, but that is all.
The most obvious differences between OBD1 and OBD2 wrt 993(aka911 for registration purposes) is
1)DME - 55pin for OBD1/88 pin for OBD2
2)wiring harness - OBD1/88 pin for OBD2
3) O sensor # & position - 1 centrally located pre cat sensor at the merge for the L/R banks for OBD1/2 pre and 2 post cat sensors for each bank(total of 4)
afaik the 1st use of OBD2 was for the RoW MY95 993tt which was N/A in the US untill MY96. All 993tt are OBD2. Only US '96 up 993na are OBD2, all RoW 993 na and US thru MY95 are OBD1.
That's why I chose a MY95 993 for my MY97 993RS engine to be transplanted into.
Bill Verburg
Old 02-10-2009, 11:00 AM
kristoj's Avatar
Just curious, which model year first had OBD I?
John Kristoff
1988 911 Carrera Cabriolet
1989 BMW M3
1982 Fiat Spider Turbo
Old 02-10-2009, 11:10 AM
I don't know which was first but, '89 964 had an OBD1 port
Bill Verburg
Old 02-10-2009, 11:13 AM
That was 1995.
964's were simply OBD and used Porsche's proprietary system of monitoring and diagnostics.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-10-2009, 11:30 AM
Originally Posted by Steve@Rennsport View Post
That was 1995.
There is a need to differentiate OBD from the various Motronic version of engine management.
OBD - On board diagnostics has been used in various usually propriatary forms from ~1975. The first universal standard was promulgated by CARB(California Air Resources Board) ~1987. It specified that all cars sold in Ca. from MY88 on have some basic OBD capability. It wasn't specifically called OBD1 untill they came out w/ OBD2 for MY96 up.
The Porsche training manuals don't specificly refer to OBD1 or OBD2 but they do lump the 964 and 993 thru MY95 together along w/ the RoW 993 thru MY98, noting the diffference between the 993 version(DME 2.10.1 used for 993) and earlier version w/ unspecified DME version # used for 964 and the still earlier Motronic versions used on Carrera 3.2.
the '96 up use DME version is 5.2 and is used along w/ OBD2
Bill Verburg
Old 02-10-2009, 02:23 PM
rattlsnak's Avatar
I agree, I was talking cars in general, as he didnt specify.
Bottom line, quickest way to tell is as Bill stated. Check how many O2 sensors it has.!
Old 02-10-2009, 02:56 PM
