Navin Johnson
Here a a few engine we built with EFI&ITBs
Bills 3.8, in this pic you can see the twin injector rails. We tuned this so at part throttle the engine is running one set of injectors, as soon as manifold pressure goes positive the second set of injector fire. ![]() Plenum removed, you can kind of make out two injectors per barrel. ![]() These are single injector ITBs with plenum ![]() 3.7 na ![]() 3.9 na
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
All the CAD drawings are done and we are getting all the parts machined next week. The test car for it is my 3.0 litre '79 SC, but we have sized the throttle bodies so that they will work equally well on a 3.2. It incorporates filtration and velocity stacks / trumpets. My company is an AEM dealer, so we will run it with the AEM Universal Engine Management System. There is a video about the AEM Universal EMS here ... http://www.tunersgroup.com/Videos/AEM_Universal_Engine_Management_System_EMS_Video.h tml My motor is out of my SC at the moment as we're rebuilding the 915 transmission, so we're developing the ITB EFI setup while the engine is out of the car - much easier to do on an engine stand than in the engine bay ! I'll post some photos of the setup next week once we have the parts machined. I originally decided to develop it for my own car, but we may offer it as a kit. - Adam
Sydney Australia Managing Director, Tuners Group, A division of Waenick Pty Ltd www.tunersgroup.com Last edited by TunersGroup; 02-08-2009 at 08:13 AM.. |
Tim:
How is the quality of the TWM bodies? jp |
subscribing
Navin Johnson
TWM 3003 and 3006 series throttle bodies are a good quality ITBs.....You will not have any hardware problems using them
We have used them in a number of builds... There are a number of other manufacturers on the market which look good as well... Jenvey, PMO, Extrudabody, Hargett makes what looks like a really nice product... I want to use them (Hargett) on the next iteration of my own 2.2 screamer. Cant remember the name now... but someone makes CF barrel valves which you an fit to a 911..Maybe Lumenition>?
Here is another good alternative.
![]() These have 46mm throttles but we have 50mm ones, too.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve:
Is that the same engine you discussed with me? jp |
Thats one of them,...(this one is a 3.4).
Steve, what are the pros and cons to a high butterfully/injector setup like that?
Do you have any dyno sheets comparing that high butterfly setup to a lower butterfly setup ? I'd be very interested to see the differences on the dyno graphs. - Adam
Sydney Australia Managing Director, Tuners Group, A division of Waenick Pty Ltd www.tunersgroup.com |
(the shotguns)
Re. the offset dual injectors on a slide valve...i'd guess if you center a single injector over a slide valve setup you're not going to get all the fuel at part throttle.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
1984-911 M491
![]() PMO ITB's, 26#/HR injectors, TECgt ECU, Tech Edge Wideband O2.
1984-911 TLC......SOLD |
ITBs
This is what we had at the PRI show 08
![]() ![]() we have a lot of call after the show on this set up ![]() This is not a full engine this was just made up of part at the shop for the show Mack emerald performance your USA Jenvey dealer
do your home work befor you spend your cash Last edited by bug man nrg; 06-14-2009 at 07:47 AM.. |
Subscribed. I had a TEC and TWM setup back in the 90's but had a hard time tuning it for street use. Things have come a long way on the EFI side.
Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900 |
Here's a pic of my 2.8 with TWM throttle bodies, 3.2 injectors, Haltech F10 ECU and Electromotive twin-plug ignition. Recent Mustang dyno tuning by John Holleran in Pinole (SF Bay Area) has resulted in immediate cold starting, 900rpm idle and excellent power/throttle response. Its never run better.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
