Old 60's Porsche Tech
head temp sensor when to replace?
I have an 85 carrera. I checked the head temp sensor, it is the two wire type. I have measure the resistance with an ohlm meter and it is to specs. The car runs great with 170k on the clock. Should it be changed out as a matter of good maintenance practices? Will it get me stranded if it fails and is there a get home method if it fails?
thanks JL |
The two wire version is the update from the old one-wire sensor.
Check the fuel pump/dme relay under the seat as that is more likely to fail. I still see original relays on 3.2 cars, it's only a matter of time......
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
temp sensor
if you have the updated one and the resistance checks out is there any other reason to replace it? JL
I would say in you have the engine out or are "in there", I would replace it. Mine rendered me nearly immobile at 55k but at 15 years of age. Agree with the DME relay comments too. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Maybe it's just me, but it almost seems as rational as replacing your DME control unit while your driver seat is out.
I know that a failed control unit will also stop you dead in your tracks too. And don't forget the fuel pump as long as the car is in the air. Where does it end? What happened to AAA? Cheers, Joe Last edited by stlrj; 02-09-2009 at 09:35 AM.. |
