Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Never had a problem with this setup and it's been over 3yrs now. Besides, I have lots of spares from prototype development from parts scoured from my local auto recycler. Another benefit that these parts bring is the fact that they have been tested on millions of Chrysler and Jeep vehicles on the road today with a reliability that would put the Porsche factory to shame. Additionally, all these components are all HEI (high energy ignition) rated which means I can gap my plugs to 0.060" to take full advantage of the stock DME ignition performance potential without having to resort to any overrated aftermarket ignition systems. As it turns out, the only part that really needed to be modified was the rotor to match up with the larger diameter distributor cap. The rest of the parts are basically off the shelf OEM Chrysler ignition cables and a Jeep Cherokee distributor cap. Cheers, Joe 74 w/ 86 3.2 conversion Last edited by stlrj; 02-11-2009 at 10:57 AM.. |
Carmagic.us
From which Chrysler car are the ignition cables ? Would they fit into the original Bosch or Marelli cap?
Thanks for sharing your retrofit !
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
These cables would not fit Bosch or Marelli caps unless, of course, you cut off the Chrysler ends and crimped on the Bosch ends, that's why I went with the Chrysler/Jeep cap to make everything compatible while maintaining the integrity of the complete HEI system. But why go to the trouble of crimping the Bosch ends on each individual wire when it's so much easier to piggyback a Chrysler rotor on a Bosch rotor and you're done. Last edited by stlrj; 02-14-2009 at 05:32 PM.. |
73 911 3.2
I got Magnecor on the Porsche, the Miata and the Suburban.
Patrice 1973 911 3.2 former track and AX car. 2016 VW GTI S PP |
