crustychief's Avatar
replacing window guide, what is the tape ..
That is on the top outside of the door and rolls down under the slot seal? Is it just really thick vinyl tape or something that I can get at a autobody supply shop, ( or Vons?). I would like to replace mine while I am in there.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-13-2009, 12:07 PM
O.K since nobody knows, I will just clean up what I have and put some RTV on the cracked spots.
Old 02-13-2009, 02:41 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
i cant tell by your description what you are refering too....that could be why no responses.
photo would help
is it a seal? did you do a search?
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 02-13-2009, 02:48 PM
I searched. it is just tape on the outside of the door, it goes under the metal strip with the squeegee on it, I assume it is for added protection from the weather. I used some RTV and a lot of love, so I think it will be fine. I will post pics in a different thread since I documented the replacement of the window guide, and slot seal.
Old 02-13-2009, 03:22 PM
Cooper911SC's Avatar
Hi Crusty,
I know what you are talking about. Not sure exactly what it is...however, it looks an awful lot like the 8mil thick (.008) clear bra material that I install.
Like you described, kind of a thick tape that the aluminum trim presses down over. I'll try looking in PET to see if they actually list a part #.
It seems like just an addditional seal or buffer to help the trim keep from moving around/vibrating.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 02-13-2009, 03:42 PM
pozee's Avatar
Look at this thread.
Is that what you're asking about?
door belt moulding tape?
pozee
Old 02-14-2009, 02:19 PM
group911@aol.co's Avatar
I've used a good quality electrical tape for years and it works fine.
Thanks,
Bob
group911@aol.com
Old 02-14-2009, 02:34 PM
