how to remove the vent control
hello all,
not sure how to remove the vent controls in an early 911 (1970). I want to take out the metal strip with the basket weave, but I am stuck at the vent control mechanism. All help welcome. michael |
Almost Banned Once
There should a bolt under the dash that holds the controls in place... there is a steel tab from the controls going back to it.
My car is a 78 so it may be different
Work in Progress
It is true that there is a bolt back up under the dash that will loosen the vent controls. Note where the big thick rubber washer goes when you disconnect it though.
To remove it completely I have had to remove the cables that go into the front trunk. Maybe someone has another solution, but I never saw any other way to do it. Without removing the cables the unit will come free and be mobile a couple of inches, but you won't be able to get it all the way out. I suppose you could disconnect the cables on the control unit but I have always found that difficult and with the cramped space I never saw an easy way to do that. Reinstalling the cables was easier than I thought it would be, and I even felt like I ran the cables back better than they originally were. Just adjust them and make sure everything is working before you put everything back together in the front trunk.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
