frankc's Avatar
Removing engine bay cable ties
Can the five cable ties along the back (front?) of the engine bay be removed from the cross-member without destroying them (see picture)? I am getting ready to paint my engine bay and need to remove these. If they do get destroyed in the process, does anyone know the part number for replacements? A couple of possibilities from PET on the harnesses page:
999.513.002.40 tie-wrap
999.513.023.40 tie-wrap
thanks,
Frank
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-21-2009, 07:39 PM
They are available but I ordered three different one to find the right ones I will try to find my old invoice to get the right part #.
Lorne M.
83 SC
Old 02-21-2009, 07:49 PM
Almost Banned Once
sc_rufctr's Avatar
I took mine out without damaging them but I used a small pick to release the tags.
Just gentle raise one side away from the body and use a pick to push the tag back. When you get one out the others are easy.
I was impressed at the quality of these. After I cleaned them they looked brand new.
Old 02-21-2009, 07:58 PM
grab the short tab with pliers and slightly angle it until it releases the strip. totally reuseable
206 637 4071
Old 02-21-2009, 08:15 PM
frankc's Avatar
Great - thanks!
I took mine out without damaging them but I used a small pick to release the tags. Just gentle raise one side away from the body and use a pick to push the tag back.
Thanks for the info - I'll give this a try tomorrow. So this is a double-barbed type retaining clip then I assume?
Frank
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-21-2009, 08:21 PM
frankc's Avatar
Wow, it's been four years since I started this thread and I'm finally shipping the chassis off to the body shop this week. One of the last items I had to do before sending it off was to remove these cable ties in the engine compartment. I found one that was a little loose and did as John Walker suggested to remove it.
For those interested, once I had it out I could see that it is uses a plunger style mechanism to expand the tabs holding it in place (see photo). Unfortunately there is no way to get under the clamp to push the pin back out. Of course you could simply push the pin all the way through to remove the clamp easily, but then you wouldn't be able to retrieve the pin so it would not be re-usable (unless you happen to have some spare pins laying around).
I still would like to find the part number for these as removing them by using JW's method does damage them slightly. And I've only removed one so far that was a little loose to begin with, so I suspect more damage on the remaining four.
Cable tie with pin retracted:
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 04-01-2013, 10:00 PM
ROW '78 911 Targa
timmy2's Avatar
Try heating a needle red hot and then sticking it in the plastic retaining pin. When it cools it should pull out. Then twist the pin off the needle.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-01-2013, 10:09 PM
wow I know that I have a slight tendency to put things off but I still haven't got you the part numbers for those tie wraps yet but I do have about 8 or 10 new ones.
Lorne M.
83 SC
Old 04-01-2013, 11:54 PM
Norm Faustino's Avatar
I've had good results with these on my classic mini. They hold like hell.
Mag Daddy Zip-Daddy Fasteners - SummitRacing.com
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 04-02-2013, 07:27 AM
I have 10 or 12 of the original Porsche tie wraps, if anyone is still looking
Lorne M.
83 SC
Old 06-11-2013, 09:17 PM
Synchro Joe's Avatar
Try Clips & Fasteners in Anaheim, CA maybe. ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 06-11-2013, 09:22 PM
frankc's Avatar
Lorne,
Thanks! I will take 5 of them as I was unsuccessful in removing the other 4 without breaking or having to push the pin through. Send me a PM with how much you would like and I can PayPal the money over to you (or whatever payment method you would like).
Norm,
Those magnetic zip-tie holders look like they will come in handy for some other areas. Thanks for bringing them to my attention.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 06-11-2013, 09:47 PM
ties
Lorne M.
I'll take however many you have leftover.
sending a pm.
thanks,
~Chris
Old 06-12-2013, 04:27 AM
Sorry guys I was wrong I only have one of the type shown above but 18 of the second type
Lorne M.
83 SC
Old 06-12-2013, 07:03 PM
ROW '78 911 Targa
timmy2's Avatar
Find your invoice yet?
Old 06-12-2013, 07:55 PM
I am hiding that pile of invoices from my wife, it looks to be about 3/4 inch think now (most from Pelican)
Plus I do have a tendency to forget to do things
Lorne M.
83 SC
Old 06-12-2013, 08:29 PM
I finally dug out the Hidden invoice folder , it is away over an inch thick, but I got the part numbers
99951300340
99951302040
99951302340
The trouble is that I don't know which of the tie wraps are which
Lorne M.
83 SC
Old 06-13-2013, 12:37 PM
frankc's Avatar
To provide some closure to this thread, I ordered various part numbers I found in PET for cable ties, and can now confirm that the part number for the engine harness ties (shown in posts #1 and #6 of this thread) is:
999-513-023-40
I hope this helps someone with a future project.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-06-2014, 06:39 PM
999-513-023-40
It did. Thank You!
Derrick
Old 03-05-2018, 08:04 AM
999-513-023-40
It sure did. Thanks Frankc!
Sure is great when people add the resolution to the end of a thread !!
1978 SC Targa
Old 03-06-2019, 03:38 PM
