<insert witty title here>
How's the other end of your input shaft? And the pilot bearing in the flywheel? I ask because that was the cause of my shifting problems - the pilot bearing had disintegrated into nothing and the end of the shaft was worn. I was able to have it chromed and ground, rather than replacing it - about $200. See the pics on p. 1 of my rebuild thread:
Christien's 915 rebuild
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
On this pinion bearing issue. I did some research and am not happy. Yes...my bearing is spun ![]() However, it is not loose to the point that it moves around. I can spin it in its position. And I can remove it. But it slides in and out tightly. So I am HOPING that I am a canidate for the Loctite solution. The Wevo solution is $ 1,000 plus I'm very afraid to mess with the differential. What are the symptoms of a spun bearing by the way?
Matt. 83 911SC 85.5 944 NA - Sold |
I saw that when I previously read your thread. The input shaft looks good. As for the pilot bearing on the flywheel...I have no idea. This transmission didn't come off my car. I got it as a core from a fellow Pelican and I'm rebuilding it so I can keep driving my car while I'm doing the work. I haven't dropped the engine yet.
Ah, ok, gotcha - sorry if you mentioned that earlier and I missed it. Smart move, rebuilding a 2nd one so you can keep driving! When you swap it out, remember to have a look. The pilot bearing is cheap - $22 if memory serves. Oh yeah, and replace your RMS! I didn't, but will when I pull the engine/tranny again in a week or 2 for a reseal.
I'm not sure what all the symptoms of a spun bearing race would be, but I think one might be a pattern of movement on the outside of the race and the inside of the bore the race fits into in the housing. I think a normal race has a fairly shiny surface on the outside just like the outside edges of the inside where the roller bearings do not touch. If you see dull or black marks on the outside it might mean its been moving around. What I did was to measure the o/d of the race and the i/d of the bore and found the difference to be only a few thousands. Plus, the inside surface of the bore where the race fit in was still smooth with no apparent damage. Therefore, I decided to take a chance and use Loctite 648 Retaining Compound which is a high strength/temperature product for retaining close fittings/press fit cylindrical assemblies. I think if the race is not too loose, and can't be wiggled side to side with your fingers, it may work. At least I'm hoping it will. Dom
Dom 1985 Black 911 Targa (Sold) 2007 Chev Malibu SS (wifey's car) |
2. Loctite sleeve retainer will not work, and peening usually won't either. Remove the diff carrier bearing races from the housing and cover (mark them or replace them!), buy a new bearing for the P/S, pack up the housing, side cover, and the outer bearing race and prep it for shipment. The machine shop that I use (in Los Angeles) will do the reinforcement that I do on all the 915s that I repair - $150. PM me for their address if you want to go this way. Bear with me, I would send a couple photos, but I'm using a temp PC - my big-bucks Dell laptop took a dump and is being repaired! Pete
Keep the Shiny Side UP! Pete Z. |
Here are some pictures of what the race and the housing looks like. ![]() ![]() There is some visible wear on the outside ring...so it definitely was spinning. However, it fits in the hole tight still. I measured the gap between the race and the housing to be .076mm. So I'm thinking I should be able to use the loctite. The 660 version is made for spun bearings. It's also supposed to fill gaps up to .020". Pete...I wrote this before seeing your post. I'm going to PM you for info.
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 03-08-2009 at 03:14 PM.. |
Pics of Opened up 5th Gear
![]() ![]() ![]() ![]() ![]() The brake bands, anchor/stop blocks, and dog teeth I think look fine. Can I just replace the synchro, or do I need to replace the internals as well?
1st Gear
![]() ![]() ![]() ![]() The brake bands and anchor/stop blocks look okay here too? Do they need to be replaced?
2nd Gear
![]() ![]() ![]() ![]() A bit more wear on the brake band on this gear for some reason.
Immature Member
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Slumlord
I would definitely try the Loctite, provided, as the good Dentist said, there are no cracks.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Matt: pm sent. Re: 2nd gear - the critical thing is to measure the new synchro in its installed position. You can have wear on the inside of the dog teeth that you really can't see, but that wear will allow the synchro to rest outside the factory acceptable range and cause terrible shifting even with a new slider (which must be replaced with new synchro rings). Order your 1/2 synchro rings and your 1/2 slider. Measure your new 2nd synchro (no groove) after installation, if it's too big then you can order your new dog teeth.
FYI: Anchor blocks, brake bands and energizer blocks are pretty bullet-proof. Usually they are damaged during major synchro failure, if they look good and no trauma has occurred you can normally re-use them. The bearing opening crack in the housing pictured above is wild - and fortunately so rare that I've never seen one like it!
With exception of 2nd Gear I think all the brake bands, anchor/stop blocks look good enough to reuse. In regards to the differential race bearing. Thanks for PMing me the shop info. I responded to you, but I'll post here to for other people to comment. If I send the differential case to a shop for reinforcment, I have to remove the differential. With all the info on here about preload, backlash, etc...it's kind of scaring me that its not a DIY job. Can anyone comment? Also, if anyone knows of any shops in the NY/NJ/CT area that may be local to me I'd appreciate it.
Matt. 83 911SC 85.5 944 NA - Sold Last edited by arbita1; 03-09-2009 at 09:43 AM.. |
Slumlord
Matt, if RENNWERKE in Elmsford, NY is reasonably close to you, Cheech the owner and his people are very good and I'm sure they could set the differential up for you.
Dom
2. Every diff housing that I've had reinforced I have replaced the diff carrier bearings, and have measured pinion depth, pre-load and backlash. I have never had to alter an original setting. If you put the old carrier bearings back in you might have to re-set pre-load (sometimes they loosen up), but that will not effect pinion depth or backlash. You will not lose any settings by simply R&I the diff...
I spoke to Bill at EMS. He was very nice. They charge $ 300 + shipping to reinforce the race bearing. He said they bore it and insert a new steel sleeve that the new race can be pressed into. I wish I could find someone local though, so I wouldn't have to pay for all the shipping...seems wastefull. Maybe tomorrow I'll give Gary Fairbanks a call and see what he recommends. Honestly...I still haven't completely ruled out the loctite solution either.
Slumlord
How much play do you have? And (Peter Z) why do you say no to the loctite? Concentricity issues?
I'm a loser, baby.
Ugh, I wish I had the ability to do this.
1979 911 SC |
