A/C Compressor in car with nopressure
I know this is a dumb question, because I couldnt find anybody else who askd it and I know nothing about A/C systems
Does leaving the A/C compressor in the engine bay hooked up with the belt but having no pressure in the system eventually ruin the compressor? Obviously, not trying to use it for cooling purposes I ask because the system has been empty for some time and I just disconnected a condenser hose... I plan to continue to run it this way for a while. Thanks in advance
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Not as long as you don't turn it on. When it's off the clutch won't engage so the compressor itself doesn't turn. The OE systems don't have any low or high pressure cut out switches though, so if you turn the AC system on the clutch will start and it has to have refrigerant to keep lubricant in the compressor.
You could also just remove the belt.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
zugelassener benutzer
Take the compressor off and leave the mount - save some weight, free up some room. It's an easy job. Also the trunk/grill mounted evap, just a few screws and hoses, and you'll get more air in the grill.
BEFORE ![]() AFTER
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
I actually preffer AC in a street car, especially one I spend 2-3 hours a day on, I'm just going to have to find a better way to plumb the AC Thanks for your help
I just spent last summer baking my arse off and the last few months not being able to see a thing for a good 20 minutes in the morning. I repaced the blower motor yesterday. Now I'm going to have to find a solution for the AC. Having a 3.6 in an SC/Carrera chassis does create the need for a few interesting work-arounds.
If you take it out of the car, you should close up the connections from the liquid line and suction line of the AC (hi side and Lo-side) The best solution would be to find an AC tech to evacuate the compressor and store it in a vacuum. Another alternative is to positively charge it with nitrogen to about 25 lbs.
This would keep the internal parts rust free for you.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
