Originally Posted by captainlewis View Post
thanks for the input. I fill the car at the exact same station the exact same pump parked at exactly the same spot when I refill, as an update retested intake manifolds for vacuum leaks disconnected the o2 sensor and idle speed controll valve, and it surged at idle will do the intake manifold gaskets and go from there, JL
But how many gallons did you fill? 2 gallons after a 50 mile test drive or 16 gallons when the spare tire bubble is full of air?
Assumptions, assumptions....assumptions.
Old 03-05-2009, 11:30 AM
Old 60's Porsche Tech
captainlewis's Avatar
tire pressure to factory specs, standard size tires, aligment has been checked, can check afr no load at 3200 and let you know, JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 03-05-2009, 12:02 PM
Update!!! plug wires and distributor cap tested perfect with ohm meter. Put a set of magnecors on and a new distributor cap and it was worth 2 Mpg, JL
Old 03-18-2009, 10:34 PM
