Old 60's Porsche Tech
captainlewis's Avatar
need confirmation i think i found my mileage problem!!!
Just tested coil in 1985 carrera I hope my bentley manual is correct it says that ohms resistance between terminal 1 and 15 on the coil (primary resistance) should be
.4 - .7 ohms. I just tested it and the ohms value is 1.2. I have been getting poor mileage and every thing else tests ok. I have been chasing this for weeks, can some one check me out on this, before I break out a cold one to celebrate, thank you JL
Old 02-24-2009, 06:40 PM
E Sully's Avatar
I tested my new replacment coil purchased from our host. I read .4 ohms.
Old 02-24-2009, 07:40 PM
T77911S's Avatar
touch your leads together, subract that from your 1.2.
i would not worry about it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-25-2009, 03:22 AM
have you changed your o2 sensor....a bad one will richen your car and affect gas milage.
Old 02-25-2009, 01:50 PM
O2 sensor was replaced when somog done 2 weeks ago, passed very clean with no adjustments, JL
Old 02-25-2009, 02:39 PM
pozee's Avatar
Your coil may be fine and not the issue. Did you test between terminals 1 and 4?
Resistance should be 0.4 to 0.6 ohms between terminals 1(-) & 15(+) and 650 to 790 ohms between 1(-) and 4(dist.wire term.)
pozee
Old 02-25-2009, 02:46 PM
You are correct the coil tested 1.2 across the two terinals however a fellow pelican reminded me to subract what the two leads on the ohm meter touched together reads which is .6 which means my true reading is .6 which is within spec, thank you JL
Old 02-25-2009, 03:01 PM
T77911S's Avatar
Jl??
RACE CAR:: sold
Old 02-26-2009, 04:01 AM
Wickd89's Avatar
When I first got the Pcar, I reviewed the service records and did some general stuff.
-- New plugs
-- New spark plug cables
-- New distributor cap
-- New air filter
-- New oil an filter change
etc, etc..
Only thing I need now is a valve adjustment (has been too long). Maybe that would help.
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 02-26-2009, 06:39 AM
darthracing's Avatar
Send a message via Yahoo to darthracing
So what was the result? I am on a poor mileage hunt myself - yanked the Weltmeister chip and am pondering new O2 Sensor in my 86...
86 Carrera Coupe (sold)
11 Nissan Leaf
03 Honda Civic Hybrid
91 ELECTRIC Kawasaki ZX-11
Old 01-25-2010, 08:39 PM
