Use later alternator in early 911?
I am wondering if it is possible to replace my existing Bosch 55 amp alternator (dead) with one from an 84-89 Carrera. I gather that there are wiring differences due to the internal regulator, but have heard that there are ways to re-wire. Are there any other problems with making this switch? Car is a 72 911.
Thanks!
Kevin 1972 T Targa |
Almost Banned Once
I installed an alternator from an 84-89 Carrera in my 78 SC.. Worked great but you're right there are wiring changes but it was so long ago I don't really remember what they were. Must have been simple because I did it on my own...lol...
I can't see any drawback or reasons not to do it. ![]() |
![]() ![]() ps: I didn't have to change idiot light bulb to 4 watt with Valeo alternator. Above is for Bosch alt.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 02-27-2009 at 05:37 AM.. |
Kevin, if you search here you will find a lot of information about this. But to summarize:
1) The later alternator is longer which requires a different fan housing; 2) The later alt is internally regulated which requires a small modification to the wiring; and 3) the internal reg heat soaks from the hot engine, causing it to occasionally not work and fail after a couple years
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
alternator
went through a lot of alternators last year to find one that worked.
the depth of the alternator is critical or the fan will hit the shroud. they look similar but there is a 1/2 inch? or so difference which will cause problems.. when you remove the old one measure distance from tip of the shaft to the base of the alternator, there is a pic on here somewhere of the alternator differences.
1975 911S Targa Silver Anniversary Edition |
I considered a marine digital external regulator if I had a cooked internal regulator problem.
Never the less I take care as best I can to prevent hot shut downs and letting it cook.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thread Tools | |
Rate This Thread | |
