Throw it on the ground!
Intermittent cruise control function in 1987???
I've got an intermittent functioning cruise control - VERY intermittent actually. It worked on the way to Hilton Head in 1987 and not again until a trip to Winston-Salem on Monday and it did not work on the way home.
System has a brain that I know can be rebuilt or replaced, column switch and engine compartment servo. I can hear a click on the column switch when I try to activate it. Intermittent function leads me to think it is a vacuum problem.
What say you here?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 02-27-2009, 09:00 AM
Jerome Ryals's Avatar
Mark, I also have an 87 with a similar problem but mine will work, stop to refuel and leave - - won't work, and it won't work again until you stop shut down, etc. I am also curious on this one.
Old 02-27-2009, 09:36 AM
rgrimm's Avatar
Don't count on it being vacuum. Mine was intermittent, and it turned out to be the brain. Cold solder joints can be intermittent when they start to break.
There is a troubleshooting technique with an electrical meter that rules out switches, etc. I believe there's at least a copy of it in the Bentley manual (which I don't have with me, so I can't give you any specific information).
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 02-27-2009, 01:34 PM
What say you here?
I thought the 87 and later used the electronic cruise with the servo, not the vacuum system as in the 86 and earlier?
Tim
1986 911 Cab
2008 Audi A6
Old 02-27-2009, 02:46 PM
Make Bruins Great Again
Por_sha911's Avatar
Swapping out the computer box is a 5 minute job. Trade with someone and you'll find out if its the computer.
Joe
Old 02-27-2009, 04:31 PM
mnmasotto's Avatar
Cruise Control
I have a 1987 Carrera with the same cruise control problem. Although I had my CC brain rebuilt I continued to have the same intermittent problem. I also replaced the column swith, cable and vacum hose but no fix. My mechanic said the cc systems on these cars are notorious for breaking down. After replacing the majority of the parts my wallet gave up. I figured I spent too much money and will have to live without it.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 02-27-2009, 05:01 PM
I use a mechanical throttle
works good enough
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-27-2009, 05:49 PM
86 Carrera Coupe
janz's Avatar
Location: Holyoke, Massachusetts (western end of state)
Where or who did the rebuild on your CC brain? I have an 86 and had mine rebuilt by Beckman and solved all my problems. One other item was that if your speedometer is also working intermitent that would cause your CC to do the same as it uses the electronic sensor to operate.
Old 02-27-2009, 06:00 PM
Tim
There are two vacuum line connections on the top of the servo on my 1987...the one to the rear (nipple due south of #42 on the diagram) comes off the T-connector.
Mark
1987 911 Coupe
Old 02-28-2009, 05:43 AM
Recreational User
porschenut's Avatar
It's the brain. I had exactly the same problem with my '86, and after swapping the brain with a good one it has worked perfectly and consistently every since.
Old 02-28-2009, 07:12 AM
ShakinJoe's Avatar
I have an entire brain and servo assy that I took out of my '87 track car if you are interested in buying. It does work.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 02-28-2009, 07:14 AM
Mark:
Didn't realize the 87 still had the vacuum servo. Wonder what year they went to the later unit?
Tim
1986 911 Cab
2008 Audi A6
Old 03-02-2009, 09:57 AM
