-   -   Removing Glue Residue? (http://forums.pelicanparts.com/porsche-911-technical-forum/460281-removing-glue-residue.html)
sc_rufctr 03-02-2009 04:42 PM
If it's only surface rust then it should work out fine.
Take your time and if it all seems like it's too much work just focus on one smaller area at a time. Get that done and move onto the next smallish area.
Before you know it you'll be finished. :cool:
Jim75911S 03-02-2009 05:36 PM
If there is rust to remove why don't you use a wire wheel attachment for your grinder and get the glue , paint and rust off all in one whack? Home Depot sells one that has the twisted wire and that suckker will remove anything. My .02 worth.
pgeorgeson 03-02-2009 05:36 PM
Another Pelican and I have just gone through this and compared notes in the process. We both used brake cleaner and that worked well. It is discussed in these threads:
http://forums.pelicanparts.com/california-southwest-us-az-nv/443725-plunge.html
http://forums.pelicanparts.com/california-southwest-us-az-nv/458484-my-911spec-build.html
ChkbookMechanic 03-02-2009 07:36 PM
I picked up the 3M adhesive remover and it does the job nicely. However I ran out of daylight so I've still have the driver's side to go.
