Hi ,
I am building a as close as possible 1977 customer version 935 with ´79 upgrades like Moby Dick Brakes and Upside Down Gearbox out of my regular street ´77 930. At least 90% of the repro parts of own production ! When I find time I`ll post pictures of parts and time after time of build up of chassis. Benno |
Put in an Odessey Battery and powered up the ISIS system. No big issues in getting it going. Changing location of a output and or switch function is so easy. My ISIS configuration sheet had the fuel pump setup to work off rear powercell. No big deal. You give the guys at ISIS the output on the front powercell and the HMI switch on the switch panel you want to operate the fuel pump and they create the hex file email it to you. Download from your PC to programmer and mastercell and its done, fast and easy. And Jay Harris and his staff at ISIS have been very accessable and helpful with my install. Electrical is the job I seem to want to do the least on my car and I would have to say this system makes for an easier, faster means to change out an old system that is lighter and totally adaptable to you needs.
http://forums.pelicanparts.com/uploa...1337088905.jpg Removed the stock 930 BOV setup and put a 964 turbo rubber boot and stock BOV. Much lighter and will free up some more space. http://forums.pelicanparts.com/uploa...1337089215.jpg http://forums.pelicanparts.com/uploa...1337089292.jpg A little more wiring and its back to Greg at Eurosport to finish the piping for turbo and intercooler and finally fire this thing up. I think Greg will approve of the decal. http://forums.pelicanparts.com/uploa...1337089430.jpg http://forums.pelicanparts.com/uploa...1337089992.jpg |
This is an amazing project, it's dropdead gorgeous!
looking forward to first fire up video!
Great job! Doug |
I can not wait to see this thing done. But I'd imagine no where near as much as you. Looks awesome.
Does this switch panel come with the ISIS? OR did you get it somewhere else? |
Thank You
Thanks guys for the compliments as well as encouragement for the last five years. The people that support and share their knowledge on Pelican help to push the desire to stay with these projects with so many different possibilities. I am blown away by what others on this site have done with their cars. And all you guys that have taken on a project know how tough it is to stay the course and get one completed. Greg Johnson keeps reminding me a race car is never finished................. No but this thread will be soon, hopefully it will help someone else as so many of the other projects on this forum have helped me.
A Big Thanks Pelican |
ISIS switch panel
James, the switch panel is from ISIS but did not come with the 3 cell kit. Its a new product and not on the site yet but available.
James,
The switches are new to the aftermarket side of our business. We have been selling them to our commercial customers for a while now. They are really elegant. They have a solid tactile response and the feel good under a gloved hand. The back-lights are built in and are very visible in all lighting conditions. Best of all, the entire bank of switches connects back to the MASTERCELL through just two 20-AWG wires plus power and ground. It makes wiring the dash very easy. Give us a call and we can get you more information. Jay |
Tad, you never cease to amaze me with this build. It is one of my top three that I follow religiously... And one being my own. but seriously, it's up their man. I would say it is on par with the 9M build over on Rennlist. Great stuff man.
When you coming to visit FL? Want to come down for the next 12h of Sebring!? |
Wow what a great build. Subscribed :-)
clam shell assembly
Got the inlet and outlet welded to the intercooler clam shell. Put the studs on and did final assembly and fitting into engine compartment. Had to move intercooler to the left about an inch to get clearance for outlet to turbo. Still need to cut out area where hood latch mounts to allow more clearance near belt pulley. Then section with bov need to be welded up.
http://forums.pelicanparts.com/uploa...1343483915.jpg http://forums.pelicanparts.com/uploa...1343484116.jpg http://forums.pelicanparts.com/uploa...1343484396.jpg http://forums.pelicanparts.com/uploa...1343484515.jpg http://forums.pelicanparts.com/uploa...1343484713.jpg |
Fantastic work!
pipes almost done
Time to start
Spent all week getting things buttoned up so I can crank the engine over next week. Had to make some new brackets to reposition some stuff. Hooked up all the turbo lines, boost , vacuum , etc..... lotsa hose clamps........ After engine checks out need to put the cv joints back on and adjust the new clutch cable and the hargett shifter shaft needs to be shortened and adjusted. I know the blue hose is ugly ... out of black hose .... but I'm to the point that I just want to the get it hooked up and running. Hopefully startup goes well.
http://forums.pelicanparts.com/uploa...1345865332.jpg |
Jesus, what a beast! Simply amazing and very jealous!!!
Amazing work! the blue hose actually looks good in there..adds a little color to the engine bay...http://forums.pelicanparts.com/support/smileys/clap.gif
I can't wait to hear this thing running. But probably nowhere near as much as you.
:subscribed:
What a beautiful build! :) |
Its Alive !!!!!
Okay, so yesterday got the engine to fire up and ran for about 3 or 4 minutes. It was a great feeling. Sort of anticlimatic since the alternator was not charging and the bearing for the fan had play and was rubbing against fan housing so started to replace alternator. When thats finshed will restart and do some tuning, was running lean. But before all that had to replace starter because it was drawing too many amps. Next the stock ignition crapped out when I first was trying to start a week ago. Replaced with a MSD 6-AL and MSD coil. Also a clewitt plug wire set from our host. Green sheathed wire from dizzy needed some work. So now about the only old part left in the car will be me LOL.... Hope to video engine running soon..........
http://forums.pelicanparts.com/uploa...1350008935.jpg
MSD 6-AL installed Could not get engine to idle seemed lean. Decided to go into the distributor, had noticed alot of play and sure enough the plate area surrounding the shaft has worn down and worn into the cast piece as well. I will attempt to shim this area and take out the extra play. Here are some pics will update later if this fixes the problem. http://forums.pelicanparts.com/uploa...1350009441.jpg http://forums.pelicanparts.com/uploa...1350009470.jpg http://forums.pelicanparts.com/uploa...1350009503.jpg |
Congratulations on getting this beast started. Huge accomplishment, but then again, I don't need to tell you that as you already know it.
5 months of progress
Posting pics from last five months of progress to show what all I have been working on.
Radiant panel to help shield ignition, accumulator/filter area. Early door caps striped and flocked with door panels mounted. Covers made and painted for front passenger area over oil tank and rear panel with hoses for naca ducts. Some numbers and graphic stuff on car... etc. Now for the pics http://forums.pelicanparts.com/uploa...1364621502.jpghttp://forums.pelicanparts.com/uploa...1364621736.jpghttp://forums.pelicanparts.com/uploa...1364621811.jpghttp://forums.pelicanparts.com/uploa...1364621879.jpghttp://forums.pelicanparts.com/uploa...1364621974.jpghttp://forums.pelicanparts.com/uploa...1364622052.jpghttp://forums.pelicanparts.com/uploa...1364622159.jpghttp://forums.pelicanparts.com/uploa...1364622220.jpg Ran engine up to temp several times probably hour or two total with Brad Penn break in oil. Need to drain , adjust valves, put in 20/50 oil , then off to the dyno for three runs,,,,,,,,,,get some data.................. This is where it gets interesting |
Absolutely awesome build.
Stamina isn't the word... Please post dyno stats. |
Any News SmileWavy
My Happy Place
http://forums.pelicanparts.com/uploa...1369488954.jpg
:D Got the car out to HPR for PCA DE last weekend in April. This was first time car had been driven more than a few feet. So I was probably more focused on what was going on mechanically than really enjoying driving the car. Did five out of seven sessions and would have done the other two as well but did have a few things to sort out. Had a oil leak at the banjo fittiing for the cam line. Tightened banjo bolt and seemed to solve that other than some residual oil. Shifter linkage came loose in one of the turns on a downshift. Its a Hargett shifter, did some fine adjustment and tightened everthing on shifter, also put shorter detent spring in trannie for getting into reverse easier. Overall shifting much better now. Car weighs 2407 lbs with 5 gallons of fuel and no driver. Not superlight but almost 600 pounds less than a stock 930. Running stock boost at .8 bar and its plenty for now. AFR's 11 to 12.5 Car handles great. As you can see in pics front valence was loose. Adding Dzus fastners to flares to solve that issue. Engine temp running on the track was around 180 to 185 but it was only 75 to 80 outside temp at track and three oil coolers in front does'nt hurt either. See how it does in July. http://forums.pelicanparts.com/uploa...1369490117.jpg This pic happened to be taken when shifter linkage had come completely off. Audi on my ass and I'm shifting the car by pulling and pushing the long connector shaft from the trannie. That was a hoot.................. |
http://forums.pelicanparts.com/uploa...1369502388.jpg
forgot this one, nice have pics of my car from somewhere other than my garage for the last 7 years..... |
awesome! congratulations - that's got to feel GREAT!
And I really like your car! |
Ronnie your making a good point about operating temp. I think it would be better as well to be at 200-210. I think probably will need to block off one or both small front coolers when its cool as it was in April here in Colorado. I figure once temps are in the 90's or higher my operating temps should stay in the higher range. Thx for the compliments on the car as well.
Just went through the entire thread and two words spring to mind: "congratulations" and "inspiring"!!
Thank you very much for sharing. Ben. |
Tadman,
Awesome work-of-art. I'd be very interested if you have found out how your water-to-air intercooler is working. Have you been able to take any readings of the air temps before and after the IC? Thanks, |
Dave, not currently reading the temps off of inlet or discharge for the intercooler. Its on my list to add and track from datalogger, probably a winter project. Next want to dyno and get some baseline numbers. I will probably get over on the turbo forum more at some point and post data to compare with others with 930's. Thx, Tad
930 Air Intake Mod
After looking at the airfilter tucked in that back left area got me to thinking how to maybe get better air flow and cooler air thru the decklid. I don't have the issue of big air/air intercooler on top and the space is there so this is what I came up with.
Started with a stock 930 air box, did some cutting. http://forums.pelicanparts.com/uploa...1381781346.jpg This top section will require more cuts to graft into the other section but here is basically how it will fit in. End section will bolt up as before. http://forums.pelicanparts.com/uploa...1381781669.jpg Then the intake section will be cut some more to allow an inlet to feed thru either by a long horizontal cone filter or just cut down a stock 930 filter to fit. http://forums.pelicanparts.com/uploa...1381781898.jpg http://forums.pelicanparts.com/uploa...1381781994.jpg Still alot of cutting and welding to do but this piece actual fits pretty well in relation to room available, can still get to mixture screw on top of fuel head for adjustment http://forums.pelicanparts.com/uploa...1381782643.jpg Still no dyno numbers yet, hopefully by next season. Car pulls strong from around 2000 rpm all the way to 6000 rpm with 1bar boost . AFR's lean mid range and rich WOT. Common issues for CIS but hopefully find a way smooth that out later..... |
Awesome project, bit late now but there is a guy a few blocks from me that specializes in 934/935 and usually has some sweet parts for sale if anyone is looking?
SpezialMotorer-Engine Development |
Air intake improvement ?
Airflow coming into to the air mixture bowl on CIS K jetronic has always seemed limited in its amount of flow and temp of air its passing in. Abandoning my attempt at just moving the filter and ducting to the the right side of the engine compartment which would not be of much significance anyway. While the two NACA ducts in the rear quarter windows are already feeding the water inter-cooler the next logical spot seemed to be the passenger window area. Location of the intake and filter can be easily moved so I can experiment with other locations. Took the car out around the block and terrorized the neighbors. Outside temps were in the 60's before this cold front and snow came in this weekend. Some interesting differences and sounds as well. Intake really resonates airflow feeding in when on boost, loud but this car is loud any way. Boost spooled up quicker. I have driven this car in cool temps before and I know the difference in performance that makes but this was not the same it was better more responsive.
On a side note added sensors to log intake and charge air to see how this water inter-cooler performs compared to an air/air inter-cooler. R&D fun........... http://forums.pelicanparts.com/uploa...1385142960.jpg Tight fit under rear shelf area..mainly transiton from 4" to 3" hose http://forums.pelicanparts.com/uploa...1385143030.jpg http://forums.pelicanparts.com/uploa...1385143486.jpg Intake components: Silicone 5" to 4" 90deg elbow, 4" to 3" reducer to fit 3" hose, Spectre $20 brake duct and K&N Xstream filter. 4" hose would obviously be more air flow but it will require modifying back shelf area some, not ready for that yet. |
Hi Tadman,
I am just starting a 911 project and was curious, now that you've lived with it for a year or more, how do you like the ISIS electrical system you installed? Is it everything it's made out to be & has it been trouble/glitch free for you? Thanks, Tom |
Hi Tom, well its name changed for starters to infinity box for good reason I suppose.
The system installed nicely and without a hitch and is very adaptable to changes and easy to troubleshoot a loose connection or blown fuse etc... It is goof idea to install a cutoff switch due to the constant system drain when system is on even though its a small amount. I had one of my switches programmed as a cold start for my CIS system to send fuel for 4 seconds and it works great. So the possiblities are there to do away with alot of relays and traditonal switches should you choose to do so and another plus is the weight savings. |
Thanks Tadman,
I noticed the name change when I looked up their website - unfortunate original name choice! One of the things I really LIKE about our older cars is the lack of computers and hi-tech stuff. The Infinity Box system is intriguing however because it does seem pretty logical - assuming it works. I also like less wiring and the versatility potential. I've downloaded the 3-cell system manual and read through it so I just know enough to be dangerous at this point. It doesn't talk much about reprogramming the input/output nodes - but it's possible I assume? I haven't done a full inventory of exactly what my electrical needs will be yet, but it looked like most of the stock programming would work. My car is headed towards being more of a race car, but still will be street legal, so all typical lighting functions need to work etc... but still pretty bare bones in terms of accessory circuits. You've found the durability to be good too so far? Thanks, Tom |
4 year update
I was sitting around and got on pelican forum and looked back at my thread and could not believe how much time has gone by since I posted where I was on my car. A lot of tinkering over the last few years for sure. I was playing around with airflow to the engine, intercooler, cis etc. I moved cooling for intercooler making a setup for the area under the tail. NACA ducts are moving air to engine bay, (2) UNI foam filters on the CIS which seems to work well. Moved MSD to inside rear area after failures which I assume was due to extreme heat and no problems now. Added 6 CHT sensors to data logger. Lastly changed the headers to 934 style with a larger T4 flange. Laminova intercooler also supplies water cooling to a Borg Warner EFR 7670 turbo. Added slider windows and my favorite race teams livery.
I was told once race cars are never finished, but I think Im close, and it only took me 12 years Lol. Happy New Year http://forums.pelicanparts.com/uploa...1546295296.jpg http://forums.pelicanparts.com/uploa...1546297018.jpg http://forums.pelicanparts.com/uploa...1546297468.jpg http://forums.pelicanparts.com/uploa...1546297816.jpg http://forums.pelicanparts.com/uploa...1546298094.jpg http://forums.pelicanparts.com/uploa...1546298302.jpg http://forums.pelicanparts.com/uploa...1546298685.jpg http://forums.pelicanparts.com/uploa...1546298830.jpg http://forums.pelicanparts.com/uploa...1546299175.jpg |
| All times are GMT -8. The time now is 01:04 PM. |
